Inventor Forum
ilogic to save PDF in 2 locations
16 REPLIES 16
Message 1 of 17
bengee54
2025 Views, 16 Replies
Can anyone help me; I'm trying find some code that will allow me to save a PDF in 2 different locations.
I want to save a copy on my C: drive - this part has been done, but I'd like the code expanded to save a copy on the F: drive (under a similar path to that on the C: drive.
For example, for drawing XXX-XXX.dwg (C:\Vault Workspace\CAD\Sales\Enquiries\2013\13-XXX\Drawings), I would like a PDF created in C:\Vault Workspace\CAD\Sales\Enquiries\2013\13-XXX\Drawings\PDF  (this part has been done) and i would also like a copy saved in F:\Sales\Enquiries\2013\13-XXX\Drawings\PDF.
I do not know which will be easier; to create 2 PDFs, or create 1 and copy it to F:
Can anyone help me?
16 REPLIES 16
Message 2 of 17
karthur1
in reply to: bengee54
Search for "batch Print pdf" or something like that.  You might be able to look at the code and figure out the part you need.
Message 3 of 17
pcrawley
Surely if you have already written the code for publishing a PDF to somewhere on C: then it wouldn't he a huge task to copy and paste the line of code and change the drive letter to F: ?
Often with iLogic queries it helps to post your code.  If you are not into iLogic yourself, someone here might spot the appropriate line and fix it for you.
Peter
Message 4 of 17
bengee5454
in reply to: pcrawley
Sorry its taken so long to reply, but the issue raised its head again so I searched the IV discussion pages and found a posting on the topic by ME!
the code which was given to me is below. I havent used this in a while, but believe that it creates a folder "PDF" on C: then saves the file in there.
to recap, I want a PDF saved in C: (done), then a PDF saved in the 'same' location in F: - a yes/no pop up saying something like 'Save in F:? would be helpful.
I am not experienced in writing code, hence my cry for help!
SyntaxEditor Code Snippet
Question1 = MessageBox.Show("Do you want to save a PDF to the working folder\PDF?" _,"iLogic",MessageBoxButtons.YesNo,MessageBoxIcon.Question,MessageBoxDefaultButton.Button1)
If Question1 = vbNo Then
Return
End If
'------start of iLogic-------
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
'oOptions.Value("All_Color_AS_Black") = 0'oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
End If
'get PDF target folder path
oFolder = oPath & "\PDF"
'oFolder = "F:\Sales\Enquiries\2013\" & oPath & "\PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" Rev" & oRevNum & ".pdf"
oMyFileName = oFolder & "\" & oFileName & " Rev" & oRevNum & ".pdf"
'check to see that the xls file exists
If Dir(oMyFileName) <> "" Then
Overwrite = MessageBox.Show("A PDF for this file already exists, overwrite it?", "iLogic",MessageBoxButtons.YesNo, _
If Overwrite = vbNo Then
    Return
    End If
End If
Try
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Catch
MessageBox.Show("PDF could not be saved, this may be due to another user having the file open", "iLogic" & ThisApplication.GeneralOptions.UserName & "!")
End Try
'Show message box
MessageBox.Show("Drawing saved and PDF Exported to " & oFolder & vbLf & vbLf & _
"Filename is: " & oFilename & " [" & oRevNum & "].pdf", "iLogic",MessageBoxButtons.Ok,MessageBoxIcon.Information, _
Message 5 of 17
bengee5454
in reply to: bengee5454
Please please please can someone help on this?
In response to one of the replies - 'simply change the location where it's saved....' - I have tried to amend the code (in red) but sadly, no luck. When i tried this (apostrophe removed), it gave an error. Foolishly I thought it would be that simple.
I've just been audited and was pulled up on a couple of missing files Smiley Sadhaving something like this would (hopefully) eliminate that.
End If
'oFolder = "F:\" & oPath & "\PDF"
End If
    Return
    End If
End If
Try
'Publish document
Catch
End Try
'Show message box
Message 6 of 17
pcrawley
In your red text, remove the \ after F:
The "\" is added later in the code.
Peter
Message 7 of 17
bengee5454
thanks for the reply.
I've done as you said but get the error
The given path's format is not supported
Message 8 of 17
pcrawley
Sorry, that's not right... Teach me to try and do this on my phone...
It's creating the path for the PDF by joining "F:\" and then the current path - but that could be C:\... The joined up text would read F:\C:\... and that would cause your error.
Where are you trying to save the PDF?
Peter
Message 9 of 17
bengee5454
i'm working in C:\Vault Workspace\CAD\Sales\Enquiries\2015\15-809 Hindley Additions\5. Drawings\CPV Drawings (for example)
the location where i want it saved (so everyone can see it) is:
F:\Sales\Enquiries\2015\2015\15-809 Hindley Additions\5. Drawings\CPV Drawings
Message 10 of 17
mdavis22569
try this:
strFolder = "E:\PDF\" & ThisDoc.FileName(False) 'without extension
ThisDoc.Document.SaveAs(strFolder & (".pdf") , True)
strFolder = "C:\PDF\" & ThisDoc.FileName(False) 'without extension
MessageBox.Show("All file formats saved", "File Save")
Just Change your file locations for each one to where you want it ..the E and the c....   You do need to create the PDF folder first though
Mike Davis
Message 11 of 17
mdavis22569
in reply to: mdavis22569
So it would be
strFolder = "C:\Vault Workspace\CAD\Sales\Enquiries\2015\15-809 Hindley Additions\5. Drawings\CPV Drawings\" & ThisDoc.FileName(False) 'without extension
strFolder = "F:\Sales\Enquiries\2015\2015\15-809 Hindley Additions\5. Drawings\CPV Drawings\" & ThisDoc.FileName(False) 'without extension
Mike Davis
Message 12 of 17
pcrawley
But tal will only ever save PDF files in the Hindley Additions folder. What about the next job?
This replacement for the red text ought to work for all jobs regardless of the folder name:
oFolder = "F:\" & Right(oPath, len(oPath) - 17)) & "\PDF"
Peter
Message 13 of 17
mdavis22569
You have to update the path for where you want it....
and the folder MUST be made..
or add 1 part of my code for the folder that will always be teh same and add keep the part of your code where it saves it to the workspace ....
Mike Davis
Message 14 of 17
bengee5454
hi Peter,
I do as you suggest, but get:
Error on Line 29 : End of statement expected.
Message 15 of 17
bengee5454
the PDF actually doesn't need to be in a new folder named "PDF", i'm more than happy about it being saved in the CPV Drawings folder. that might make it a ittle easier?
Message 16 of 17
pcrawley
This should do it:
oFolder = "F:\" & Right(oPath, (Len(oPath) - Len("C:\Vault Workspace\"))) & "\PDF"
It might look complicated, but it takes "F:\" then adds the current-drawing path, then adds the "\PDF" sub folder (and creates it if it doesn't exist)
The bit that makes it look complicated is all the "Len" stuff, and I'll try and explain it:
Your current drawing lives at C:\Vault Workspace\CAD\Sales\...bla bla bla
The bit in bold needs to be replaced by F:\
Len counts the number of characters in a string of text: Len("test") would return 4.
Right reads a specific number of characters from the text in brackets starting from the right.
So Right("read this", 4) would return "this".
What I did was use Len("C:\Vault Workspace\") to return 19, and Len(oPath) to return the length of your current path (93 in this instance).  So the line of code (in English!) reads:
Right(text to read starting from the right, number of characters to read)
or
Right(current path, 93 - 19)
or
Right("C:\Vault Workspace\CAD\Sales\Enquiries\2015\15-809 Hindley Additions\5. Drawings\CPV Drawings", 74)
which would extract the last 74 characters of the path;
Making the final oFolder = F:\ and CAD\Sales\Enquiries\2015\15-809 Hindley Additions\5. Drawings\CPV Drawings and \PDF
So if you don't want the extra \PDF folder, just delete & "\PDF"
You could argue "why not just work out 93-19 and put that in as a number?", but as you work on different folders in Vault, the path length changes, so the resulting folder for your PDF's needs to change too.
It will fail at one point: If you create a drawing in the root foler (C:\Vault Workspace) because Len needs to return a non-zero result, but by the looks of your folder naming and the fact that you are actually audited, I doubt that'll ever happen!
Sorry, this turned into an essay - but I know how frustrating it is having something that almost works and your stuck on the last little bit!
Peter
Message 17 of 17
bengee5454
Thank you very much Peter,
Thats exactly what I was looking for.
...and a nice explanation of the code.
Much appreciated.
