Inventor General Discussion
MikeRid
Message 1 of 4 (165 Views)
iLogic to edit document settings
165 Views, 3 Replies
04-03-2013 09:05 AM
Is there a way in iLogic to change the document setting for an .idw file?
Inventor 2013
Hi MikeRid,
This should work, just set myStandard to the standard you want to use.
I hope this helps.
Curtis
myStandard = "Default Standard (ISO)"
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
oDoc.StylesManager.ActiveStandardStyle = oDoc.StylesManager.StandardStyles(myStandard)
Curtis_Waguespack
Message 2 of 4 (162 Views)
Re: iLogic to edit document settings
04-03-2013 09:28 AM in reply to: MikeRid
Hi MikeRid,
Yes. Is there a particular setting or settings you're wanting to set? If so I'll try and provide an example.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
MikeRid
Message 3 of 4 (159 Views)
04-03-2013 09:31 AM in reply to: Curtis_Waguespack
I'd like to change the Active Standard when I switch the title block through a foms I already have active.
Thanks.
Inventor 2013
Curtis_Waguespack
Message 4 of 4 (151 Views)
04-03-2013 09:42 AM in reply to: MikeRid
Hi MikeRid,
I hope this helps.
Curtis
