Is there a way in iLogic to change the document setting for an .idw file?
Inventor 2013
Solved by Curtis_Waguespack. Go to Solution.
Hi MikeRid,
Yes. Is there a particular setting or settings you're wanting to set? If so I'll try and provide an example.
I hope this helps.
Curtis
I'd like to change the Active Standard when I switch the title block through a foms I already have active.
Thanks.
Inventor 2013
Hi MikeRid,
This should work, just set myStandard to the standard you want to use.
I hope this helps.
Curtis
myStandard = "Default Standard (ISO)"
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
oDoc.StylesManager.ActiveStandardStyle = oDoc.StylesManager.StandardStyles(myStandard)
I apologize for an unwritten rules I am breaking for replying this way.
Is there a way to check the "defer updates" box under the drawing's document settings via illogic?
I am trying to figure out a way to make my own "check in/out" process despite inventor's abilities with that already, we just don't seem to like it is all.
Hi Carrotonian,
Yep, a new topic or quick search would have likely been a better route to take.
As for your question, see this link:
I hope this helps.
Curtis
