Inventor Forum
iLogic to edit document settings
5 REPLIES 5
1525 Views, 5 Replies
Is there a way in iLogic to change the document setting for an .idw file?
Inventor 2013
5 REPLIES 5
Curtis_Waguespack
Hi MikeRid,
Yes. Is there a particular setting or settings you're wanting to set? If so I'll try and provide an example.
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
I'd like to change the Active Standard when I switch the title block through a foms I already have active.
Thanks.
Inventor 2013
Curtis_Waguespack
Hi MikeRid,
This should work, just set myStandard to the standard you want to use.
I hope this helps.
Curtis
myStandard = "Default Standard (ISO)"
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
oDoc.StylesManager.ActiveStandardStyle = oDoc.StylesManager.StandardStyles(myStandard)
Carrotonian
I apologize for an unwritten rules I am breaking for replying this way.
Is there a way to check the "defer updates" box under the drawing's document settings via illogic?
I am trying to figure out a way to make my own "check in/out" process despite inventor's abilities with that already, we just don't seem to like it is all.
Hi Carrotonian,
Yep, a new topic or quick search would have likely been a better route to take. Smiley Wink
As for your question, see this link:
http://forums.autodesk.com/t5/inventor-customization/ilogic-defer-updates-in-drawing-file/td-p/28364...
I hope this helps.
Curtis
