Inventor Forum
ilogic to create view rep
4 REPLIES 4
dclunie
3175 Views, 4 Replies
Hi
Is there Any code out there that will allow user to select part file then isolate and create view rep of that part with name of view rep the same as part.
The reason is we have lots of reps that isolate various components and this is very time consuming, I have had a look if there is Any customization because this would be a good user tool,also could work very well on assembly.
Any thoughts would be appreciated
Dave
Tags (2)
4 REPLIES 4
dclunie
in reply to: dclunie
Hi
I have noticed curtis waguespack has posted latest blog to get all file names and folder from parts using vb code vis selectset command.Code for this  is below.
I am convinced with very minor tweaks and removing message boxes this code could be used to create my view rep  via ilogic.
  1. select part file
  2. get file name without extension (.ipt)
  3. isolte part and creat view rep with name same as step (2)
  4. lock view rep
  5. return to master view
I have had a go at compiling code to do this but i am a just a beginner at vb,any help would be appreciated?
below is link to code that curtis posted for me to creat view rep by material type.
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-set-Design-View-Representation-by-material/td...
'get currently selected component
Dim oOccurrence as ComponentOccurrence
Try
  oOccurrence = ThisDoc.Document.SelectSet.Item(1)
Catch
  MessageBox.Show("Please select a component before running this rule.", "iLogic")
  Return
End Try
Dim doc As Document
Dim CurFileName As String
'set the selected item
oOccurrence = ThisApplication.ActiveDocument.SelectSet.Item(1)
'get the selected item document occurrence name
doc = oOccurrence.Definition.Document
'get the path and file name of the selected item
CurFileName = doc.FullFileName
'defines backslash as the subdirectory separator
Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
'find the postion of the last backslash in the path
FNamePos = InStrRev(CurFileName, "\", -1)
'get the file name with the file extension
Name = Right(CurFileName, Len(CurFileName) - FNamePos)
'get the file name (without extension)
ShortName = Left(Name, Len(Name) - 4)
'get the path of the folder containing the file
Folder_Location = Left(CurFileName, Len(CurFileName) - Len(Name))
MessageBox.Show("File Name: " & Name _
& vblf & "File Name without extension: " & ShortName _
& vblf & "File Path: " & Folder_Location _
& vblf & "Path and File Name: " & CurFileName, "iLogic")
'------------ end of ilogic--------------------
Tags (1)
Curtis_Waguespack
Hi dclunie,
I think the rule in this text file will do what you're after. It creates a vew rep for each unique part in the assembly.
Note: This rule has a flaw (if you have two instances of a part in the assembly (PartA:1 and PartA:2) and you delete instance one (PartA:1), the rule does not make a view rep. It needs to be fixed so that it looks for the first instance of each part, rather than instance " :1" of each part, but havn't had time to get that sorted.
I hope this helps.
Curtis
Here's the code for the rule, but beware of line wraps that might cause it to cut and paste incorrectly.  Use the text file instead.
'create a design view representation for each unique part in the assembly
'define current document
Dim openDoc As Document
openDoc = ThisDoc.Document
'set a reference to the assembly component definintion.
'this assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'look at all of the components in the assembly
Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition
'define the first level components collection
Dim oCompOcc As Inventor.ComponentOccurrence
'define view rep
Dim oViewRep As DesignViewRepresentation
'define an arraylist to hold the list of  view rep names
Dim NameList As New ArrayList()
'Look at the view reps in the assembly
For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations
'set the list of names to the array list
NameList.add(oViewRep.Name)
Next
'check for a Default view rep and create it if not found
If Not NameList.Contains("Default") Then
	'create Default view rep
	oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Default")
	oViewRep.ShowAll
	oViewRep.Activate
End If
'zoom all
ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
'look at all of the unique parts in the assembly
For Each docFile In openDoc.AllReferencedDocuments
	If docFile.DocumentType = 12290 Then '12290 is the part document enumurator
	'locate the last backslash position in the full file name
	Dim FNamePos As Long
	FNamePos = InStrRev(docFile.FullFileName, "\", -1)
	'remove path from part file name
	Dim docFName As String
	docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
	'remove extension from part file name
	ShortName = Left(docFName,  Len(docFName) - 4)
		'check to see if the arraylist contains the desired view rep
		If Not NameList.Contains(ShortName) Then
		'create new View Rep
		oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(ShortName)
		oViewRep.Activate
		oViewRep.Locked = False
		Else If NameList.Contains(ShortName) Then
		'reference existing View Rep
		oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(ShortName)
		oViewRep.Activate
		End If
		'look at all of the occurences
		For Each oCompOcc in oCompDef.Occurrences
		'locate the colon position in the occurence name
		oCompOccPos = InStrRev(oCompOcc.Name, ":")
		'set occurence name to everything left of the colon
		oOccName = Left(oCompOcc.Name, oCompOccPos -1)
			'set visible if name matches first occurence
	      	If oCompOcc.Name = ShortName & ":1"  Then
			oCompOcc.Visible = True
			ThisApplication.ActiveView.Update()
			Else
			oCompOcc.Visible = False
			End If
		Next
	End If
	'lock view rep
	oViewRep.Locked = True
Next
'set Default View Rep active
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").activate
dclunie
in reply to: Curtis_Waguespack
Hi
I have been playing with code for a while and is very good at what it does but i was wondering can we take it to next level.
I still need view reps of parts same as before with rep name same as part without  extension,however can we get it to only create a veiwrep if it finds text in a custom property called desc2
We controll all our manufactured parts that need some kind of machining opertation to it with internal code ie bevel/ , rout/,rip to pattern/ etc .
So we have create viewreps on dwgs for these parts to show operatives how to machine parts.normally this would not be a large task but some of our models have upto 20 isolated veiwreps per assembly and we have a lot of assemblys so it is very time consuming.
dave
@Curtis_Waguespack
I used your code and it works great with one exception, when I run this rule in an assembly that uses Frame generator, it creates the views but does not turn-on the visibility of the corresponding part. I am guessing it cant find the shortname in the browser because a Frame Generator file type has a different enumerator or maybe because the individual frame generator part has a Modeling tab and a Frame Generator Tab? Note: I have Unique Numbers turned on for all Fram Gen parts.
