Inventor General Discussion
Active Contributor
3 Kudos
Post 1 of 3
iLogic to change the view representation in a part file
690 Views, 2 Replies
04-16-2012 09:14 AM
There is an existing thread on this forum showing how to change the view rep in an assembly (using oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Red").activate) - Thank you to Curtis Waguespack - however I am trying to achieve the same with iLogic in a part file (multi-solid). Is this possible please?
Many thanks
Following iLogic rule activates "View1" and should work both in a part or in an assembly.
Keep in mind that viewreps capture the part and body appearance in a multi-body part but not the face or feature appearance.
Dim odoc As Document
Dim ocompdef As ComponentDefinition
odoc = ThisApplication.ActiveDocument
ocompdef = odoc.ComponentDefinition
Try
ocompdef.RepresentationsManager.DesignViewRepresentations.Item("View1").Activate
Catch
MessageBox.Show("This viewrep does not exist", "Error")
End Try
 Bob
Product Support
47 Kudos
Post 2 of 3
Re: iLogic to change the view representation in a part file
04-16-2012 09:58 AM in reply to: CadlineSupport
Try
Catch
End Try
 Bob
Active Contributor
3 Kudos
Post 3 of 3
04-16-2012 12:59 PM in reply to: CadlineSupport
Superb! works perfectly thank you very much for the quick response
