Inventor Forum
ILOGIC - say yes to any prompt help needed
6 REPLIES 6
DeerSpotter
805 Views, 6 Replies
I dont know ilogic well enough yet, and i need help (inpot) on how to properly automate a "yes" or "yes to all" to any prompt that comes up when i run my ilogic codes?
ANy help will be appreciated with a smile 🙂
thanks!
Image and video hosting by TinyPic
See My LinkedIn Profile
6 REPLIES 6
mrattray
in reply to: DeerSpotter
Can I assume this is because you're running a rule that involves a save operation?If so, then you need to check this option in the rule generating the save prompt. This will just use whatever the default option is.
Mike (not Matt) Rattray
DeerSpotter
in reply to: mrattray
I will definitly look at that, but no its not for a save opperation.
the ilogic wants to edit read only files or sowmthing like that, and we always press yes and yes to all, it doesnt make the difference. it's annoying to sit there and press yes all the time.
mrattray
I don't understand. Are these rules you got from somwhere and they're generating prompts that you don't want? If this is the case then if you post the code, I can probably rewrite it to not prompt you.
DeerSpotter
well its an inventor box that is titles "Vault" and i get 4 options. yes, yes to all, no, no to all.
and the weird part, yes to all doesnt work.
so if i could put in code to say yes to all to all prompts that pop up that would be awesome!
mrattray
I don't think there's any way to do what you want to do.
DeerSpotter
this is what i get during my ilogic runs..
