Solved by JamieSENG. Go to Solution.
Hi Jamie,
Have you tried adding a trigger to your rule? You can use the event trigger "After Open Document" so everytime you open a drawing it will run the rule automatically. You could even try "Close Document" so when you close the drawing it will run your rule.
Do you know how to add triggers?
Kind Regards
Jo
