Inventor General Discussion
Distinguished Contributor
22 Kudos
Post 1 of 3
iLogic - save as .pdf rule question
473 Views, 2 Replies
10-24-2012 02:29 AM
I'm currently using this rule for easy PDF making
SaveLoc = "C:\Temp\"
FileName = ThisDoc.FileName(False)
Revnr = " rev_" & iProperties.Value("Project", "Revision Number")
PDFnaam = SaveLoc & FileName & Revnr
ThisDoc.Document.SaveAs(PDFnaam & (".pdf") , True)
MessageBox.Show("PDF is aangemaakt in C:\Temp\", "Document creation",MessageBoxButtons.OK,MessageBoxIcon.Information)
 The problem with this is that i want to save without lineweight? is there anyway to do this with this code?
Thanks!
Inventor 2013
0 Kudos
Post 2 of 3
Re: iLogic - save as .pdf rule question
10-24-2012 08:02 AM in reply to: Jefkee
6 Kudos
Post 3 of 3
02-19-2013 03:03 PM in reply to: WernerBeek
is it there rule that make pdf in short version. For instance: i have 50 sheets of pdf's and i need them and i have rule for that. But i need only few first sheets too for customer. They need to be in numerical order 1 of 3, 2 of 3 of 3 etc. They are not happy with numbers on pages like 1of 50 ,2 of  50, etc.
If you guys can help please.
Thank you
