I'm currently using this rule for easy PDF making
SaveLoc = "C:\Temp\" FileName = ThisDoc.FileName(False) Revnr = " rev_" & iProperties.Value("Project", "Revision Number") PDFnaam = SaveLoc & FileName & Revnr ThisDoc.Document.SaveAs(PDFnaam & (".pdf") , True) MessageBox.Show("PDF is aangemaakt in C:\Temp\", "Document creation",MessageBoxButtons.OK,MessageBoxIcon.Information)
The problem with this is that i want to save without lineweight? is there anyway to do this with this code?
Thanks!
See this link:
http://inventortrenches.blogspot.nl/2011/07/ilogic-to-save-pdf-files-to-new.html
Groeten,
Werner
is it there rule that make pdf in short version. For instance: i have 50 sheets of pdf's and i need them and i have rule for that. But i need only few first sheets too for customer. They need to be in numerical order 1 of 3, 2 of 3 of 3 etc. They are not happy with numbers on pages like 1of 50 ,2 of 50, etc.
If you guys can help please.
Thank you
