Inventor Forum
Ilogic rule to read out user parameter of ipart
1 REPLY 1
WernerBeek
410 Views, 1 Reply
Dear all,
I've created a main assembly containing several ipart components. With the following rule I can read the model parameters, but not the user parameters of the iparts:
A = Parameter("Part1:1", "d0")
If I create a component, insert it in the main assembly and make it an ipart afterwards, the user paremeters can be read out with help of ilogic. But if I insert the same ipart again, the user parameters can not be read out anymore. Model parameters are no problem.
Does anyone have a solution?
Thanking you in advance,
Werner
1 REPLY 1
mrattray
in reply to: WernerBeek
iLogic and iParts don't get along. You'll find many more problems like this if you continue to try to force them to coexist.
Mike (not Matt) Rattray
