Inventor Forum
iLogic Rule to Print String to Parts List
14 REPLIES 14
Message 1 of 15
TomTom111
4341 Views, 14 Replies
I am trying to make an iLogic rule that gets mutliple strings from different places, and prints them to a user property in the Parts List.
My ultimate goal is to print the drawing number, sheet number and the item column value to the user property with the format being...
"XXXXX-X-X"
So far, i can get the drawing number from an iProperty and the sheet number easily. But im getting stumped on obtaining the item coloum value and printing it to the same row.
This is what i have so far...
Dim DWGNUM As String = iProperties.Value("custom", "DWG Number")
SheetNumber = Mid(ThisDoc.Document.ActiveSheet.Name, InStr(1, ThisDoc.Document.ActiveSheet.Name, ":") + 1)
MessageBox.Show(DWGNUM+"-"+SheetNumber, "DXF Number")
And print the message box output to a column in the parts list
Any help is appreciated!
Thanks in advanced
14 REPLIES 14
Message 2 of 15
cmt-edgar
in reply to: TomTom111
Hey everyone, I work with Thomas and have been assisting where i can on the iLogic rule, we have been able to generate the "dxf" number for each row now, dxf number being "Drawing Number - Sheet Number - Item Number"
ex: 123456-7-8. What we would like it to do now is reference/scan our custom iProperty column called "Overall Dim" wich gives us the length of a structual component (10 1/4") or the overall length and width of a sheetmetal component (15 1/8" x 32 1/2"). Our goal is for the iLogic rule to recognize wether or not the "x" is present or not and only generate a dxf for those rows with the x. and then ultimately write that information in our custom DXF No column.
Message 3 of 15
Hi cmt-edgar,
Here's a quick example of using the String.Contains method to do this.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
s1 =  iProperties.Value("Custom", "Overall Dim")
Dim s2 As String = "x"
Dim b As Boolean
b = s1.Contains(s2)
If b = True Then
MessageBox.Show(s1 & " does contain: " & s2, "iLogic")
Else
MessageBox.Show(s1 & " does NOT contain: " & s2, "iLogic")
End if
Message 4 of 15
Thanks Curtis!
This will definitely help.
Is there a way to use the String.Contains method to check a column of the Parts List in the current drawing?
We want to check if a specific cell of the Parts List has an "x", and if it does, we want to write the "dxf" number (Drawing Number - Sheet Number - Item Number) to a cell in the same row as the number tested.
The cell that will contain the DXF number is a user property in the parts list.
Thanks for the help.
Message 5 of 15
Hi TomTom111,
Here's a quick ilogic example that iterates through the parts list and reads each cell. I'm not sure how you plan tol identify the specific cell to look at so I didn't really look into targeting a specific cell. But hopefully you can use it to work up a solution with the previous example, if not post back and I'll have another look.
I hope this helps.
Curtis
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the first parts list on the active sheet.
    ' This assumes that a parts list is on the active sheet.
    Dim oPartList As PartsList
    oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
    ' Iterate through the contents of the parts list.
    Dim i As Long
    For i = 1 To oPartList.PartsListRows.Count
        ' Get the current row.
        Dim oRow As PartsListRow
        oRow = oPartList.PartsListRows.Item(i)
       ' Iterate through each column in the row.
        Dim j As Long
        For j = 1 To oPartList.PartsListColumns.Count
            ' Get the current cell.
            Dim oCell As PartsListCell
            oCell = oRow.Item(j)
          'Display the value of the current cell.
           sCell = "Row: " & i & vblf & oPartList.PartsListColumns.Item(j).Title & " = "& oCell.Value
	Dim Result = MessageBox.Show( sCell , "iLogic",MessageBoxButtons.OKCancel)
	If Result = DialogResult.Cancel Then
	Return
	Else
	End If
        Next
    Next
Message 6 of 15
Thank you Curtis,
your expertise has been most helpful.
So now i can show only the values of a certain coloum.
Hopefully, my final question would be-
Can you change the value of a cell in the Parts List with an iLogic rule, or are the cells of the Parts List 'Read Only'?
If you can, what is the code for that?
Say the parts list cell is blank, and you want to wrint a string of text to it.
Message 7 of 15
Hi TomTom111,
Here's a quick example that looks for a part number and then writes to the description column of that row if the part number matches.
I hope this helps.
Curtis
Dim i As Long
'look at only the part number column
oCell  = oPartList.PartsListRows.Item(i).Item("PART NUMBER")
	'find a specific part number
	If oCell.Value = "12-345" Then
	'identify the cell in the description column for the row that
	'the part number was found in
	oCell2 = oPartList.PartsListRows.Item(i).Item("DESCRIPTION")
	'write to the target cell
	oCell2.Value = "Bingo!"
	End if
Next
Message 8 of 15
This works great!
Thank you for your time in helping me along with this!
*Expert_Elite* for a reason apparently.
P.S.
Your blog is also of much help.
Thanks much
Message 9 of 15
what if you wanted to use a table not a parts list. Thanks for any help
Message 10 of 15
hi!
It's possible to have a rule how take a total square feet of each material in partlist?
Thanks for your help!
Message 11 of 15
If you can break the process into an easy, logical procedure, chances are like 95% that you can do it with code.
It's just a matter of finding the necessary resources and learning the programming language to implement it.
Some resources for anyone wanting to learn more:
Google: "msdn + vb.net + ________"
API Reference: C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm
Blog: http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Blog: http://beinginventive.typepad.com/being-inventive/
Blog: http://adndevblog.typepad.com/manufacturing/
Autodesk Developer Network Github: https://github.com/ADN-DevTech/Inventor-Training-Material
Good luck!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 12 of 15
Thanks for the links MechMachine 🙂
Maybe i found the solution?
Message 13 of 15
Hi Curtise;
Although this is an old posting, I found it useful (or learnt from your coding) to find the total weight as per the BOM in the drawing. Shown below is the generic coding (user needs to input for the QTY and Weight column number in BOM and units of weight as well) I developed.
oCol_Qty = InputBox("COLUMN NUMBER FOR QTY PER ASS'Y: ", "COLUMN NUMBER: QTY", "Column Number - QTY")
oCol_WT = InputBox("COLUMN NUMBER FOR WEIGHT: ", "COLUMN NUMBER: WEIGHT", "Column Number - WT")
Dim oWT_Units_Array As New ArrayList
oLBS =  "LBS"
oKG = "Kg"
'get the materials collection
'get the desired material from the collection
oWT_Units_Array.add(oLBS)
oWT_Units_Array.add(oKG)
oWT_LBS_Kg = InputListBox("SELECT FROM ABOVE!", oWT_Units_Array, oWT_Units_Array.Item(0), "WT: LBS OR Kg", "WEIGHT UNITS")
WT_Total = 0
Dim i As Long
oCell_UWT = oPartList.PartsListRows.Item(i).Item(Val(oCol_Qty)).Value
oCell_QTY = oPartList.PartsListRows.Item(i).Item(Val(oCol_WT)).Value
WT_ithRow = Val(oCell_UWT)*Val(oCell_QTY)
WT_Total = WT_Total + WT_ithRow
'MessageBox.Show("ROW NUMBER: " & i _
'& vbLf & "oCell_UWT: " & oCell_UWT _
'& vbLf & "oCell_QTY: " & oCell_QTY _
'& vbLf & "WT_ithRow: " & WT_ithRow _
'& vbLf & "WT_Total: " & WT_Total, "Title")
Next
'MessageBox.Show("oPartList.PartsListRows.Count: " & oPartList.PartsListRows.Count, "Title")
iProperties.Value("Custom", "WEIGHT") = CStr(WT_Total) & " " & oWT_LBS_Kg
iLogicVb.UpdateWhenDone = True
I believe, by now, you may have a better idea for this purpose.
I request you reply me with comments. You are busy - take your time.
Message 14 of 15
Hi @RoyWickrama_RWEI,
If you're just wanting to get the mass from the assembly, you can access that information more directly as in this example:
'get the document from the first
'drawing view
Dim oMdoc As Document
oMdoc = ThisDrawing.ModelDocument
' Get the mass
Dim dMass As Double
dMass = oMdoc.ComponentDefinition.MassProperties.Mass
' Get the UnitsOfMeasure object
Dim oUOM As UnitsOfMeasure
oUOM = oMdoc.UnitsOfMeasure
'Convert the mass to the current document units
Dim sMass As String
sMass = oUOM.GetStringFromValue(dMass, oUOM.GetStringFromType(oUOM.MassUnits))
'get the units string
sUnit = oUOM.GetStringFromType(oUOM.MassUnits)
'Format Units String
If sUnit = "lbmass" Then
	sMass = Replace(sMass, "lbmass", "LBS")
Else If sUnit = "kg" Then
	sMass = Replace(sMass, "kg", "Kg")
End If
MessageBox.Show("Total Weight: " & sMass, "iLogic")
iProperties.Value("Custom", "WEIGHT") = sMass
However, if there truly is a need to read the information from the parts list here is another example that is similar to the one you posted:
'get the column titles/headers
Dim oHeaderList As New ArrayList
For i = 1 To oPartList.PartsListColumns.Count
	oTitle = oPartList.PartsListColumns.Item(i).Title
 	oHeaderList.add(oTitle)
Next
'get user input
oCol_Qty = InputListBox("Select the QTY column", _
oHeaderList, oHeaderList.Item(0), "iLogic", "Column Titles:")
oCol_WT = InputListBox("Select the WEIGHT column", _
bUnit = InputRadioBox("Select unit", "LBS", "Kg", True, "iLogic")
'evaluate user input for unit
'and set string
If bUnit = True Then
	bUnit = "LBS"
Else
	bUnit = "Kg"
End If
'multiply the QTY by Weight for each row
'add add values for total
WT_Total = 0
	oCell_QTY = oPartList.PartsListRows.Item(i).Item(oCol_Qty).Value
	oCell_UWT = oPartList.PartsListRows.Item(i).Item(oCol_WT).Value
	WT_ithRow = Val(oCell_UWT)* Val(oCell_QTY)
Next
MessageBox.Show("Total Weight: " & WT_Total & " " & bUnit, "iLogic")
I hope this helps.
Curtis
Message 15 of 15
Thanks a lot for taking time to reply to my request: it is not only the solution but also some kind of information useful in my ILogic pursuits.
