Inventor General Discussion
Valued Contributor
dclunie
Message 1 of 4 (710 Views)
ILogic rule to change all units
710 Views, 3 Replies
11-25-2012 09:07 PM
Hi All
I am after a rule to change the unit type of all .ipts from cm to mm.
This has to go down to all levels in hierarchy  but only change .ipt files
any code would be appreciated
 Dave
Curtis_Waguespack
Message 2 of 4 (687 Views)
Re: ILogic rule to change all units
11-26-2012 10:11 AM in reply to: dclunie
Hi dclunie,
I think this will work for you (if you modify it a bit):
'get input from user
oUnit = InputRadioBox("Select a units of measure type", "Metric", "Imperial", False, "ilogic")
If oUnit = True then
'set to millimeter
oUOM_1 = UnitsTypeEnum.kMillimeterLengthUnits
'set to kilogram
oUOM_2 = UnitsTypeEnum.kKilogramMassUnits
Else
'set to inch
oUOM_1 = UnitsTypeEnum.kInchLengthUnits
'set to pounds mass
oUOM_2 = UnitsTypeEnum.kLbMassMassUnits
End if
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
	'look at only part files
	 If docFile.DocumentType = kPartDocumentObject Then
	'format  file name
	Dim FNamePos As Long
	FNamePos = InStrRev(docFile.FullFileName, "\", -1)
	Dim docFName As String
	docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
	'set length units
	docFile.unitsofmeasure.LengthUnits = oUOM_1
	'set mass units
	docFile.unitsofmeasure.MassUnits = oUOM_2
	'rebuild to update the display
	docFile.Rebuild
	End If
Next
iLogicVb.UpdateWhenDone = True
This is a variation of this rule:
http://inventortrenches.blogspot.com/2012/05/ilogic-rule-to-change-units-of-measure.html
 I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Curtis_Waguespack
Message 3 of 4 (679 Views)
11-26-2012 10:22 AM in reply to: Curtis_Waguespack
Here's a version specifically, directed toward changing from mm to cm:
oUnit = InputRadioBox("Select a units of measure type", "millimeter", "centimeter", True, "ilogic")
'set to millimeter
Else
'set to centimeter
oUOM_1 = UnitsTypeEnum.kCentimeterLengthUnits
End if
	'format  file name
	'set length units
	docFile.Rebuild
	End If
Next
 I hope this helps.
Curtis
scottmoyse
Message 4 of 4 (564 Views)
03-18-2013 12:48 PM in reply to: Curtis_Waguespack
Curtis,
Since the OP didn't say thank you I will. This just saved one of my staff a tonne of time. Thank you very much!
Cheers
Scott.
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
