Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ilogic replace component with multiple different components
32 REPLIES 32
Message 1 of 33
Ben-Cornelius
13949 Views, 32 Replies
So I have been going round and round in circles on this one iam trying to use replace component within ilogic which is fine with switching one part for another but I want a drop down of parts so it replaces which ever one is active the problem I am having is establishing which one is active. So below is what I have so far but the problem is you cant seem to reference a part that is not in the assembly so I keep getting the error
The component named "Flange 1" was not found for example. Any ideas? I just need a way of establishing which one is currently in the assembly but with out referencing components that are not there.
If Component.IsActive("Flange 1")=True Then current = 1
If Component.IsActive("Flange 2")=True Then current = 2
If Component.IsActive("Flange 3")=True Then current = 3
If part = 1 And current = 2 Then Component.Replace("flange 2", "Flange 1.ipt", True) End If
If part = 1 And current = 3 Then Component.Replace("flange 3", "Flange 1.ipt", True) End If
If part = 2 And current = 1 Then Component.Replace("flange 1", "Flange 2.ipt", True) End If
If part = 2 And current = 3 Then Component.Replace("flange 3", "Flange 2.ipt", True) End If
If part = 3 And current = 1 Then Component.Replace("flange 1", "Flange 3.ipt", True) End If
If part = 3 And current = 2 Then Component.Replace("flange 2", "Flange 3.ipt", True) End If
32 REPLIES 32
Message 2 of 33
pcrawley
in reply to: Ben-Cornelius
Put all the parts in the assembly - then suppress the ones you don't want using iLogic.
The iLogic suppression is different to the Inventor LOD suppression in that it effectively removes the part from the BOM - so an iLogic suppression becomes really useful.
Peter
Message 3 of 33
Ben-Cornelius
in reply to: pcrawley
Yeah i know you can do that and also using iparts but I would like the option to do this way and to know if this is even possible
Message 4 of 33
Do check out the below link
https://grabcad.com/library/ilogic-place-replace-remove-component-in-assembly-1
Do check out the video to understand the ilogic program....
hope the assembly file with ilogic code in my Grabcad site answers your requirement.....
Carthik Babu M.S, Asst Manager - Machine Building,
Gabriel India Ltd,Hosur, TN, INDIA
Email:carthik_ms@yahoo.co.in ,
https://grabcad.com/carthik-1/projects
"May all beings be happy" http://www.dhamma.org/
Message 5 of 33
thanks but not really what I wanted but I have now figured it out so for anyone fustrated trying to do this here is the code. So the first line gets the components name based on its browser location so that can't change.
My_Variable2 = ThisDoc.Document.ComponentDefinition.Occurrences.Item(2).Name
If flange = 1 Then
Component.Replace(My_Variable2, "Flange 1.ipt", True)
If flange = 2 Then
Component.Replace(My_Variable2, "Flange 2.ipt", True)
If flange = 3 Then
Component.Replace(My_Variable2, "Flange 3.ipt", True)
and so on.......
Message 6 of 33
I was wondering do you happen to know how to add rules to replace the ipart component? If there is any example for that? Thank you!
Message 7 of 33
well normally you would just change the row of the ipart so iPart.ChangeRow("iComponentName:1", "RowMemberName"). Are you referring to that or do you want to completely replace this with another component or ipart?
Message 8 of 33
Yes, this answered my question! Thank you very much!
Message 9 of 33
Hello There,
Thanks for your post,
I am trying to do the same.
I have an assembly where I have 20,30,35 or 40 mm bearing.
I need to replace bearing to suit correct size.
I have started with 25 mm bearing, and able to change 25 mm to suit other sizes.
But once I have changed size, I am not able to change it to suit other size, as 25 mm bearing does not exsist in assembly.
If Bearing_DIA_D=35 Then
Component.Replace("FB205 (25):1", "FB207 (35).ipt", True)
Else If Bearing_DIA_D=30 Then
Component.Replace("FB205 (25):1", "FB206 (30).ipt", True)
Else If Bearing_DIA_D=40 Then
Component.Replace("FB205 (25):1", "FB208 (40).ipt", True)
InventorVb.DocumentUpdate()
Your code seems the solution for my problem, but as I do not have programming background, got a bit confused on how to use it.
Can you please help by giving explainaton of each line in code and each function?
Regards
Paarg
Message 10 of 33
Hi
So what this is doing is getting the name based upon the browser location so you will have to change the item number based on where the part is that you want to change
Component.Replace(My_Variable2, "FB207 (35).ipt", True)
Component.Replace(My_Variable2, "FB206 (30).ipt", True)
Component.Replace(My_Variable2, "FB208 (40).ipt", True)
Message 11 of 33
Hello Bendesign04 (Sorry not sure what your name is!)
New to this site, didnot get email about your reply,
Just logged in to check and got your reply, checked it straight away.
Thank you,
That worked.
Much appriciate your support and help.
Regards
Parag
Message 12 of 33
P_Korgaonkar
in reply to: P_Korgaonkar
Hello All,
Once again I have run in to issue.
When I replcae part using following code, it is replacing all parts rather than only one instance.
I have Cover (206):1 in position 4
and
Cover (206):2 in position 6.
I want to change only one of them depending on statement/condition.
but code i have written below replaces both covers.
I tied additional 0 and 1 after last comma, but made no differnce. any suggessitons?
SyntaxEditor Code Snippet
My_Variable3 = ThisDoc.Document.ComponentDefinition.Occurrences.Item(3).Name
My_Variable4 = ThisDoc.Document.ComponentDefinition.Occurrences.Item(4).Name
My_Variable5 = ThisDoc.Document.ComponentDefinition.Occurrences.Item(5).Name
My_Variable6 = ThisDoc.Document.ComponentDefinition.Occurrences.Item(6).Name
If Bearing_DA=30 And SIDE_NO = 1 ul Then
Component.Replace(My_Variable3, "FB206 (30).ipt", True, 0)
Component.Replace (My_Variable4, "Cover (206).ipt" , True, 0)
Component.Replace(My_Variable6, "Cover Closed (206).ipt", True, 0)
Else If Bearing_DA=30 And SIDE_NO = 0 ul Then
Component.Replace (My_Variable4, "Cover Closed (206).ipt" , True, 0)
Component.Replace(My_Variable6, "Cover (206).ipt", True, 0)
Message 13 of 33
Hi parag,
To replace just one instance of the component change the variable after the component name, from True to False as shown:
ComponentOccurrence.Replace( FileName As String, ReplaceAll As Boolean )
True = ReplaceAll
Component.Replace("My_Part_File.ipt", False)
I hope this helps.
Curtis
Message 14 of 33
Thanks Curtis,
It worked.
My work colleague mentioned your name yesterday, I searched for you on google and visited your blog
Great work,
Thanks a ton for your contribution to CAD community.
Is there any online resource which explains every possible command in Ilogic with its sub options like this one you explained.
thanks once again
Regards
Parag
Message 15 of 33
Hi parag,
You can find the Inventor API Help files and Example code by going to the Help link within in Inventor (top right corner) as shown here:
And here are some other links:
http://usa.autodesk.com/adsk/servlet/index?id=1079044&siteID=123112
http://inventortrenches.blogspot.com/2013/10/ilogic-how-to-learn-inventors.html
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Message 16 of 33
Thanks Curtis,
Very useful inormation.
Regards
Parag
Message 17 of 33
andrewb
While what Ben has told you is a completely viable option, it can be done in a simpler manner.
Instead of basing your code on the item location, simply "stabilize" the item name. This way it will not change after your iLogic script runs.
In your browser double-click (slow click) on your component. Change it to something such as "Bearing". Your code would then look like this:
Component.Replace("Bearing", "FB207 (35).ipt", True)
Component.Replace("Bearing", "FB206 (30).ipt", True)
Component.Replace("Bearing", "FB208 (40).ipt", True)
Message 18 of 33
P_Korgaonkar
in reply to: andrewb
Thanks Andrew,
Yes what you say is right, but it brings along limitations.
You can change that part once only, once the part is replaced, the name changes, and you cant replace it anymore because of different name.
Unless you can guide me to replace the name of part after it is placed in to assembly to be same as before replacement, in this case "Bearimg"
is ther a way to do it?
so after the replacement, next line of code would change that name to become Bearing again!
Regards
Parag
Message 19 of 33
The code SyntaxEditor Code Snippet
will return the part name in this top level assembly. but what should I use if I need one from a sub assembly?
Message 20 of 33
P_Korgaonkar
in reply to: sharathsb721
Hello sharathsb721
with my limited knowledge and experience,
this is what I have done.
I have named every instance of component I may replace.
and in code I have given instance name.
It works for me.
Haven't tried in sub assembly level.
as an option you ,may run code from sub assembly.
Or some one will suggest code for sub assembly.
If Bearing_DA=20 And SIDE_NO = 1 ul Then 'Side A when bearing is inside
Component.Replace("Bearing DA" , "FB204 (20).ipt", False)
Component.Replace ("Cover DA", "Cover (204).ipt" , False)
Else If Bearing_DA=20 And SIDE_NO = 0 ul Then 'Side B when bearing is inside
Component.Replace("Bearing DA", "FB204 (20).ipt", False)
Component.Replace ("Cover DA", "Cover Closed (204).ipt" , False)
all the best
regards
parag
