Inventor General Discussion
Member
djgrooster
Message 1 of 2 (283 Views)
iLogic Reading beginning of Filename
283 Views, 1 Replies
06-06-2013 09:57 AM
I'm attempting to create a rule using iLogic, which reads the first two letters of either the File Name or Part number (Which ever is easier)
i.e. if a part number was AB12345, I would want the code to recognize the "AB"
At which point I'm trying to use an If-Then-Else statement to modifiy the material of the part, dependent on the first two characters of the File name.
Is this possible?
As an example, where the underlined portion is what i don't know how to code:
If  iProperties.Value("Project", "Part Number") Begins with "AB" Then
    iProperties.Material = "Steel"
Else If iProperties.Value("Project", "Part Number") Begins with "AC" Then
    iProperties.Material = "Aluminum"
End If
-Dan
I Figured this one out i went with
If Left(iProperties.Value("Project", "Part Number"),2)= "AB" Then
Else If Left(iProperties.Value("Project", "Part Number"),2)= "AC" Then
    iProperties.Material= "Aluminum"
End If
Member
djgrooster
Message 2 of 2 (267 Views)
Re: iLogic Reading beginning of Filename
06-06-2013 11:44 AM in reply to: djgrooster
End If
