Inventor Forum
iLogic Questions (Wildcards, assy folders, & pushing parameters)
4 REPLIES 4
2251 Views, 4 Replies
Using IV2013
1.) I found a post that says that iLogic doesn't support wildcards. Are there any workarounds for this? For example, say I want a rule to suppress all hex bolts regardless of size in an assembly. Assuming all hex bolts will have the term "HEX BOLT" in the name, can such a rule be made?
2.) I was wondering if iLogic can access assembly (browser) folders to manipulate all files under it. For example, I have an assembly folder named "Hardware". Can iLogic access that folder by name?
3.) When an equation driven parameter gets pushed between files via an iLogic rule only the value is pushed instead of the equasion. For example, an IAM and IPT has the parameter with equation "PlaneElevation=Height/2". With iLogic this value is to be pushed from the IAM to IPT but if I change the IAM equation to "Height/4" then the IPT's "PlaneElevation" value loses the equation and is replaced with only the numerical value. What I'd like is the IPT's parameter to also read "Height/4".
Thanks.
MechMan
4 REPLIES 4
cwhetten
Ok, here are some answers for you.
1)  I don't know whether or not iLogic (or even VB.net) can use wildcards.  But assuming it can't, you can work around it by using something similar to this:
'Get the set of occurrences in this assembly document
oOccurrences = ThisDoc.Document.ComponentDefinition.Occurrences
'Cycle through each component in the set
For Each oComp As ComponentOccurrence In oOccurrences
	'Get the browser name of the component
	oCompName = oComp.Name
	'Check if the desired bit of text is in the component's name
	If InStr(oCompName, "HEX BOLT") > 0 Then
		If oComp.Suppressed Then
			'If the component is already suppressed, do whatever you want to it here
		Else
			'If the component is NOT already suppressed, do whatever you want to it here
		End If
	End If
Next
 The above code checks the browser name for each component in your assembly to see if it has "HEX BOLT" in it somewhere.  This bit of text is case sensitive, so it has to match EXACTLY.  If your components' names vary slightly, you will have to account for that variation.
2)  Here is some example code that accesses a browser folder and cycles through each object in the folder (in this example, it toggles the suppression state):
'Get the normal assembly browser pane object
oPane = ThisDoc.Document.BrowserPanes.Item("AmBrowserArrangement")
'Get the browser folder object
oFolder = oPane.TopNode.BrowserFolders.Item("Hardware")
'Get the set of nodes in the folder
oFolderNodes = oFolder.BrowserNode.BrowserNodes
'Cycle through each browser node in the folder
For Each oNode As BrowserNode In oFolderNodes
	'Get the actual object that the node represents, in this case, assembly components
	oComp = oNode.NativeObject
	'Do whatever you want to the component.  In this example, toggle the suppression state
		oComp.Unsuppress
	Else
		oComp.Suppress
	End If
Next
3)  Manipulating the parameter expression is much easier than I thought it would be.  Below is some code that does what you describe:
p = PlaneElevation 'This line doesn't actually do anything, but it makes sure this rule fires when PlaneElevation is changed
'Use Parameter.Param to get the actual parameter object.  This is used below to access the expressions of the parameters.
oAsmParam = Parameter.Param("PlaneElevation")
oCompParam = Parameter.Param("SubComponent Name", "PlaneElevation")
'You probably want to pass the value of the Height parameter, since PlaneElevation depends on it
Parameter("SubComponent Name", "Height") = Height
'The following line sets the expression of the component paremeter to equal the expression of the assembly parameter.
oCompParam.Expression = oAsmParam.Expression
Post back if you have any questions.
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
in reply to: cwhetten
Great Answers Cameron! You even defined everything very well for a code newbie such as myself.
I wouldn't mind hearing from Adesk or someone whether my questions are actual iLogic limitations.
MechMan
DeerSpotter
 This is amazing stuff, Check out how i expounded on it. This code below is a External Rule. Basically i needed to turn off visibility of a part that can be a different part name every single time. The way i target it is in the iproperties. If iproperties is this, then do this. This is soo easy.
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
If openDoc.DocumentType = 12291 Then
	For Each docFile In openDoc.AllReferencedDocuments
		If docFile.DocumentType = 12290 Then
			Dim FNamePos As Long
            FNamePos = InStrRev(docFile.FullFileName, "\", -1)
            Dim docFName As String
            docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
			If iProperties.Value(docFName, "Project", "Description")="ENDPLATE" Then
			ShortName = Left(docFName, Len(docFName) - 4)
				If Component.Visible(ShortName & ":2") = True Then
					Component.Visible(ShortName & ":2") = False
					Component.Visible(ShortName & ":1") = False
				Else
				If Component.Visible(ShortName & ":2") = False Then
					Component.Visible(ShortName & ":1") = True
				End If
			End If
				'rebuild/refresh document to see results
				ThisDoc.Document.Rebuild()
			End If
		End If
	Next
	Else
	MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
End If
this code is suppressing features in a .ipt:
			If iProperties.Value(docFName, "Project", "Description")="BASEPLATE" Then
				'iProperties.Value(docFName, "Project", "Description") = iProperties.Value(docFName, "Custom", "DISPLAY_NAME")
				'iLogicVb.RunRule(docFName, "GROUT HOLES")
				'ThisDoc.Document.Rebuild()
				If Feature.IsActive(docFName, "GROUT HOLES (REFERENCE ONLY)") = True Then
   					Feature.IsActive(docFName, "GROUT HOLES (REFERENCE ONLY)") = False
				Else
					If Feature.IsActive(docFName, "GROUT HOLES (REFERENCE ONLY)") = False Then
					End If
				End If
			End If
		End If
	Next
	Else
End If
this code is running a ilogic rule in a part:
				iLogicVb.RunRule(docFName, "OPEN FORM")
			End If
		End If
	Next
	Else
End If
Image and video hosting by TinyPic
See My LinkedIn Profile
andrew_canfield
Hello Cameron
Thanks for the post on suppressing folder contents - whats needed to iterate the same process through all sub assemblies?
Regards
Andrew
