Inventor Forum
ilogic part insertion
56 REPLIES 56
Message 1 of 57
GH80
19758 Views, 56 Replies
I am working on an assembly with lots of parts that are turned on and off (Component.IsActive) using ilogic, depending on which is selected. The model is for a steel door, and the parts we have constrained are all the various options for hardware, such as lock cases and door closers. All the parts are already set up in a library, but are also present in our top level assembly.
As the assembly is getting bloated with all the parts and constraints, I was wondering if it was possible to have ilogic automatically insert (and constrain) a part from a library into the active assembly, not just unsuppress a previously inserted part.
Does anyone know of a way to do this with ilogic?
Inventor 2013 SP1
56 REPLIES 56
Message 41 of 57
Carthik_Babu
in reply to: jwood14
Oops, i hope there is some problem with community mailer. I got all these update in single day ie today (29 mail for this same Topic).
Well, u got help from Swordmaster. Just pinging the below link, may be useful.
http://wikihelp.autodesk.com/Inventor/enu/2014/Help/1283-Inventor1283/3538-iLogic3538/3543-Function3...
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0673-iLogic673/0675-Conditio675
Carthik Babu M.S, Asst Manager - Machine Building,
Gabriel India Ltd,Hosur, TN, INDIA
Email:carthik_ms@yahoo.co.in ,
https://grabcad.com/carthik-1/projects
"May all beings be happy" http://www.dhamma.org/
Message 42 of 57
jwood14
in reply to: Carthik_Babu
Ha ha opps
I would like to thank you all for all of the help you have given me. You have shown me that there is another place I can turn to other than Youtube.
I have tried a few things, but I am still getting the erroe message
"Error in rule: strap_size, in document: Rolled Barrel Strap Hinge.ipt
Object reference not set to an instance of an object."
I have no idea how to set the reference to an "instance" of my hinge
Message 43 of 57
swordmaster
"Rolled Barrel Strap Hinge.ipt" this is your ipart correct?
If so the code to swap out the ipart member goes in your assembly not the ipart
Inventor 2010 Certified Professional
Message 44 of 57
jwood14
in reply to: swordmaster
Yes, that is my part number. What is the ipart number? the case number? Would you be able to give me an example?
Message 45 of 57
swordmaster
First off, answer this question
where did you place the ilogic code for swapping out the ipart members
Is it in the ipart or your assembly?
Message 46 of 57
jwood14
in the part.... but I just moved it over to the assembly
Message 47 of 57
swordmaster
good , thats where it needs to be
I think you need to do a simple test of your code first before going furher with your "real" model
create a assembly
create a parameter in the assembly named Length
Insert your hinge ipart (select any member)
Stabalize the name of the Hinge by renaming it in the model tree of the assembly
create a ilogic rule in your assembly
Insert the code for swapping out the hinge member
save everything!
now try changing the value of the Length parameter in the assembly (select from your values 18,22 etc)
the hinge should swap out when the rule is ran
Message 48 of 57
jwood14
ok, I tried to place the 22 inch and the 18 showed up, is that right?
Message 49 of 57
swordmaster
you tell me! is that the result you want?
Message 50 of 57
jwood14
oh duh! No it is not, I need it to change with the door's width, I think I have that figured out though how to tell it that if a door is between a certain range what size to pick. But no, the 22 in is supposed to show up
-Jonathon Wood A-101
Message 51 of 57
swordmaster
"oh duh! No it is not"
If it was that obvious why ask me if it was correct?
I really did not appreciate that remark. You need to test your own code
Message 52 of 57
jwood14
I'm sorry, I selected the 22" from the table list but the 18 inch came up, but I don't know why. That's not coding though is it? I told the program what each hinge was according to length and the number of holes it received, at what spacing.
Message 53 of 57
jwood14
The 18" is the only one that shows, even though I am able to select the other 5 sizes
Message 54 of 57
bhavik4244
@swordmaster @Curtis_Waguespack
I have similar kind of question, I have an excel where all occurances name are given (ipt and iam) . Could you please help me to get insert the part/assembly reading from the excel list?
your help will be highly appriciated.
Bhavik Suthar
Message 55 of 57
Curtis_Waguespack
in reply to: GH80
Hi @bhavik4244
It would probably be best for you to provide an small example file set (inventor files and excel ), and mention which version of Inventor you are using, and then someone can likely provide an example.
I hope this helps.
Curtis
Message 56 of 57
SharkDesign
in reply to: GH80
I don't think anyone has mentioned the easiest way of doing this.
You should use the manage command.
ThisAssembly.BeginManage("Group 1")
If (addCompB)
	Dim componentB = Components.Add("occName", "b.ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
ThisAssembly.EndManage("Group 1")
Group 1 can be anything, so you could have door 800, door 1200, door 1500.
Then you can use the standard code above, or you can place the mates instead.
First method using location which you can get from
ThisAssembly.BeginManage("Door 800")
If Width > 750 and If Width < 950 Dim componentA = Components.Add("occName", "a.ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing) End If ThisAssembly.EndManage("Door 800")
ThisAssembly.BeginManage("Door 1000")
If Width > 950 and If Width < 1500
ThisAssembly.EndManage("Door 1000")
Second method:
The way I do it is to put everything in that I need, mate it all and then right click the parts in the assembly tree in the iLogic dialogue and select
You'll end up with something like this:
The first method is a bit messy, and will ground all your components, the second will mate them. It's usually best to fix the names in the browser as mentioned in one of the other replies first.
Using the manage command will add and remove parts as necessary. No suppression messing things up. You need these parts on your hard drive first though, so you either need ilogic code to get from vault, or you need to manually get them.
  Expert Elite
  Inventor Certified Professional
Message 57 of 57
@Curtis_Waguespack
thanks for your reply. I have manage to solve my issue.
Bhavik Suthar
