Inventor Forum
ilogic parameter help
3 REPLIES 3
1552 Views, 3 Replies
Hi
I am after help to change some code that was supplied by Curtis Waguespack that adds description to all parts with a certain type of material,(ie finds all material that is plywood and adds a description formula to the parts within an assembly)
what i am after is a input box to change all part thicknesses of all parts that are found to new user value
User value that we use to hold thickness values in all .ipts is G_T
  1. find all .ipts within an assembly
  2. input to ask user thickness
  3. change all .ipt parameters ("G_L") that control thickness to newly inputted value
below is code used to alter descriptions on all .ipts found with material = to (plywood)
''kUnknownDocumentObject = 12289
'kPartDocumentObject = 12290
'kAssemblyDocumentObject = 12291
'kDrawingDocumentObject = 12292
'kPresentationDocumentObject = 12293
'kDesignElementDocumentObject = 12294
'kForeignModelDocumentObject = 12295
'kSATFileDocumentObject = 12296
'kNoDocument = 12297
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim mywidth As Integer
Dim docFile As Document
If openDoc.DocumentType = 12291 Then
      For Each docFile In openDoc.AllReferencedDocuments
            If docFile.DocumentType = 12290 Then
            Dim FNamePos As Long
                  FNamePos = InStrRev(docFile.FullFileName, "\", -1)
                  Dim docFName As String
                  docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
                  'select for part files with specified material
                  If iProperties.Material(docFName) = "PLYWOOD"  Then
                  'set description
                  iProperties.Value(docFName, "Project", "Description")= "=<Material> <G_L>"
                  iProperties.Value(docFName, "Project", "Part Number")  = Left(docFName, InStrRev(docFName, ".") - 1)
                  End If
            End If
      Next
      Else
      MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!")
End If
3 REPLIES 3
Curtis_Waguespack
Hi dclunie,
Here is some code that will set the Thickness parameter (if it is present) in each part file. You can use it as an example to modify your code.
I hope this helps.
Curtis
'get input from user
myThickness = InputBox("Enter Thickness", "iLogic", "0.75")
'look at all of the parts in the assembly
'get the part file names
if iProperties.Material(docFName) = "PLYWOOD"  Then
'set description
'ignore error if parameter is not in the part
Parameter.Quiet=True
'set parameter value
Parameter(docFName, "Thickness") = myThickness
End If
End If
Next
iLogicVb.UpdateWhenDone = True
in reply to: Curtis_Waguespack
HI Curtis
Excellent piece of work you just saved me hours of manual work
Many Thanks
Dave
I was under the impression that cc / ifeatures used, for eg:
100x10 Flat Bar x 500 Lg
would have:
G_W = 100
G_H = 10
G_L = 500
I was planning on using these parram names for ease of coord with existing Inventor Nomenclature
If im mistaken could you enlighten me a bit further on what parts of inventor use what parrams
Cheers
