Inventor Forum
ilogic Parameter Description help
7 REPLIES 7
Message 1 of 8
devonjohnson
1557 Views, 7 Replies
Hi there,
I have been using ilogic code I found (from Curtis W) which looks at the material selected in a part and then populates the 'Description' field with a formula.  This works great but for SHS I want to include the miter angles so I need the code to look to see if parameter "ANG1" or "ANG2" exists and if so then populate with the relevant formula.  Otherwise populate with the standard formula.  The code below includes the 'if' statements which are not working, if anyone could offer any help it would be greatly appreciated!!
Sub Main oSELECT
If iProperties.Material = "ALUMINIUM" Then
iProperties.Value("Project", "Description")="=<HEIGHT> x <WIDTH> x <THK> THK"
iProperties.Value("Custom", "TYPE")= "ALUMINIUM"
ElseIf iProperties.Material = "SS ALLTHREAD" Then
iProperties.Value("Project", "Description")="=M<DIA> x <LENGTH> LG"
iProperties.Value("Custom", "TYPE")= "SS ALLTHREAD"
ElseIf iProperties.Material = "SS ANGLE" Then
iProperties.Value("Project", "Description")="=<HEIGHT>x<WIDTH>x<THK> x <LENGTH> LG"
iProperties.Value("Custom", "TYPE")= "SS ANGLE"
ElseIf iProperties.Material = "SS FLAT" Then
iProperties.Value("Project", "Description")="=<WIDTH> x <THK> x <LENGTH> LG"
iProperties.Value("Custom", "TYPE")= "SS FLAT"
ElseIf iProperties.Material = "SS HEX" Then
iProperties.Value("Project", "Description")="=<HEIGHT>AF x <LENGTH> LG"
iProperties.Value("Custom", "TYPE")= "SS HEX"
ElseIf iProperties.Material = "SS PIPE" Then
iProperties.Value("Project", "Description")="=Ø<DIA> x <LENGTH> LG"
iProperties.Value("Custom", "TYPE")= "SS PIPE"
ElseIf iProperties.Material = "SS PLATE" Then
iProperties.Value("Custom", "TYPE")= "SS PLATE"
ElseIf iProperties.Material = "SS RHS" Then
If Parameter = ("ANG1") Then
iProperties.Value("Project", "Description")="=<HEIGHT>x<WIDTH>x<THK> x <LENGTH> LG (<ANG1> / 0)"
iProperties.Value("Custom", "TYPE")= "SS RHS"
If Parameter = ("ANG2") Then
iProperties.Value("Project", "Description")="=<HEIGHT>x<WIDTH>x<THK> x <LENGTH> LG (<ANG1> / <ANG2>)"
Else
ElseIf iProperties.Material = "SS ROUND" Then
iProperties.Value("Custom", "TYPE")= "SS ROUND"
ElseIf iProperties.Material = "SS SHEET" Then
iProperties.Value("Custom", "TYPE")= "SS SHEET"
ElseIf iProperties.Material = "SS SQUARE" Then
iProperties.Value("Project", "Description")="=<HEIGHT>SQ <LENGTH> LG"
iProperties.Value("Custom", "TYPE")= "SS SQUARE"
ElseIf iProperties.Material = "SS TUBE" Then
iProperties.Value("Project", "Description")="=<HEIGHT> x <WIDTH> x <LENGTH> LG"
iProperties.Value("Custom", "TYPE")= "SS TUBE"
ElseIf iProperties.Material = "UHMW, White" Then
iProperties.Value("Custom", "TYPE")= "UHMW, White"
ElseIf iProperties.Material = "ACETAL" Then
iProperties.Value("Custom", "TYPE")= "ACETAL"
End Sub
Devon Johnson
Inventor 2020
7 REPLIES 7
Message 2 of 8
VdVeek
in reply to: devonjohnson
Where do the parameters "ANG1" and "ANG2" come from?
It looks like the Miter is created by a split. So when you look for a Split feature you find a Miter.
This iLogic Rule is working in the part environment.
If Feature.IsActive("Split1") = True
iProperties.Value("Project", "Description")="Miter 1"
An easy way to find all the posible parameters in a rule is to select the part name under the Model Tab and RMC and click Capture Current State. This shows all the posible parameters with there names.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Message 3 of 8
devonjohnson
in reply to: VdVeek
If the section needs to have mitres, we use the cut extrusion feature and then rename the angular dimension to get it to show up in the iproperties 'Description'.  I can get the code to work if these parameters exist, but if they don't I get errors because the code is looking for them.  I need to know how to change the code to skip these parameters if they don't exist.  Any ideas on how to do this?
Devon Johnson
Inventor 2020
Message 4 of 8
mrattray
ElseIf...
  Try
  Catch
    Try
    Catch
    End Try
  End Try
ElseIf...
 Try using this instead of the extra if/else statement.
Mike (not Matt) Rattray
Message 5 of 8
devonjohnson
in reply to: mrattray
Thanks for that, its nearly there, the first expression is being added in now whether it has miters or not, so atleast I'm not getting error messages!  It has to be something very close to that, thanks again for your help.
Devon Johnson
Inventor 2020
Message 6 of 8
mrattray
If you could post up the files that your trying to run this on then I could play around with them to see what you need. I was just taking a shot in the dark with that code.
Message 7 of 8
Hi devonjohnson,
I think I would use a Select Case for this. Here's an example. Note that I'm not sure I have the If statement correct for how you want it, but you can adjust it as needed. I just set it up to work for my testing.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
'get the material in use
oMaterial = iProperties.Material
'select the case based on the material in use
'and then set the description
Select Case oMaterial
Case = "SS RHS"
	'quite errors if parameter does not exist
	Parameter.Quiet = True
	'check for the miter parameters
	If Parameter("ANG1") isnot nothing Then
	sDecr = "=<HEIGHT>x<WIDTH>x<THK> x <LENGTH> LG (<ANG1> / 0)"
	Else If Parameter("ANG2") isnot nothing Then
	sDecr = "=<HEIGHT>x<WIDTH>x<THK> x <LENGTH> LG (<ANG1> / <ANG2>)"
	Else
	sDecr ="=<HEIGHT>x<WIDTH>x<THK> x <LENGTH> LG"
Case = "ALUMINIUM"
sDecr = "=<HEIGHT> x <WIDTH> x <THK> THK"
Case = "SS ALLTHREAD"
sDecr = "=Ø<DIA> x <LENGTH> LG"
Case = "SS ANGLE"
sDecr = "=<HEIGHT>x<WIDTH>x<THK> x <LENGTH> LG"
'add more cases here as needed...
End Select
'set the iProperties
iProperties.Value("Project", "Description") = sDecr
iProperties.Value("Custom", "TYPE") = oMaterial
Message 8 of 8
devonjohnson
Hi Curtis,
That worked great thanks so much!  The only thing I had to change was the order, the ANG2 variation had to be before ANG1 or else it wasn't picked up.
Really appreciate your help, it had been driving me nuts!
Devon
Devon Johnson
Inventor 2020
