Inventor Forum
ilogic or vb help
8 REPLIES 8
Message 1 of 9
dclunie
3285 Views, 8 Replies
ilogic or vb help
Hello
I am after help on some ilogic code if any body has any snippets they could share
 1. Is there a way of searching an assembly with ilogic to find all .ipt    with a certain type of material then if found insert a formula into the    description field i;e, =<G_L> x <G_W> x <G_T>
2. Same As above but with a tweak i want to find materials again but i    want to turn visibility on/off as this would help in the aid of creating    view reps.
3. Find all .ipt within an assembly and if part number does not equal    file name without .ext then add part number to parts
Regards
Dave
Tags (2)
8 REPLIES 8
Message 2 of 9
Curtis_Waguespack
in reply to: dclunie
Hi dclunie,
I borrowed some code created by guyh and MegaJerk at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Run-ilogic-rule-in-each-part-from-the-...
and put together the following ilogic snippet to do what you're after, in this case checking for all parts using the mat'l steel.
I hope this helps.
Curtis
'kUnknownDocumentObject = 12289
'kPartDocumentObject = 12290
'kAssemblyDocumentObject = 12291
'kDrawingDocumentObject = 12292
'kPresentationDocumentObject = 12293
'kDesignElementDocumentObject = 12294
'kForeignModelDocumentObject = 12295
'kSATFileDocumentObject = 12296
'kNoDocument = 12297
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
If openDoc.DocumentType = 12291 Then
    For Each docFile In openDoc.AllReferencedDocuments
        If docFile.DocumentType = 12290 Then
            Dim FNamePos As Long
            FNamePos = InStrRev(docFile.FullFileName, "\", -1)
            Dim docFName As String
            docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
            If iProperties.Material(docFName) = "Steel"  then
            iProperties.Value(docFName, "Project", "Description")= "=<G_L> x <G_W> x <G_T>"
    Next
    Else
    MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
Message 3 of 9
Hi dclunie,
I realized I forgot to address items 2 & 3 of your request. Here's a revised version that takes care of all 3 requests. It's not the most tidy, but it works.
I hope this helps.
Curtis
''kUnknownDocumentObject = 12289
			'select for part files with specified material
			'set description
			'set part number to file name
			iProperties.Value(docFName, "Project", "Part Number")  = Left(docFName, InstrRev(docFName, ".") - 1)
				Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition
				Dim oCompOcc As Inventor.ComponentOccurrence
				For each oCompOcc in oCompDef.Occurrences
				voCompOcc = Component.InventorComponent(oCompOcc.Name)
					If iProperties.Material(docFName) = "Steel"  Then
					voCompOcc.Visible = False
				Next
	Next
	Else
Message 4 of 9
dclunie
in reply to: Curtis_Waguespack
Hi Curtis
Thank you for your quick response too my post however ,I have tried to run code but getting error messages as I am very new to ilogic code I am unable to fix attached is jpg of error box ,if I comment problem area there is no error box but code does not change anything on assembly that it has run on.
Would the code need to react any differently if running on frame generator assemblies
I have placed code from my external rule for verification that it is correct
Regards
Dave
			'set description
			iProperties.Value(docFName, "Project", "Part Number")  = Left(docFName, InStrRev(docFName, ".") - 1)
				For Each oCompOcc in oCompDef.Occurrences
				Next
	Next
	Else
	MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exc​lamation)
Regards
Dave
Message 5 of 9
Curtis_Waguespack
Hi dclunie,
The error you're seeing is due to an improper syntax in the message box line. You can just replace it with this line and it wll be fine:
MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!")
Remember to change your parts to use Steel for the material or change the code to look for a matrial you're using to see this work.
Also  just noticed that the part dealing with visiblity is not handeling subassembly structures properly, so it would need to be looked at to get to work better.
Here's the modified rule fixing the message box line and removing the visibility code.
I hope this helps.
Curtis
			'set description
	Next
	Else
Message 6 of 9
dclunie
HI Curtis
That code works a treat and really fast thank you , sorry to ask again is there a way to look for different material within the same code and do the same operation to as follows
  • find material i.e.. Timber
  • Add description to the files
  • and fix part number
then find another
  • find material i.e.. Steel
Just to explain why I need this code is all related to frame generator ,I use frame generator to build Upto 8000 part holiday homes and we use a formula within the description of all parts attached vie frame member and in some occasions or description formula gets wiped out and is no longer linked to exported parameters so the description fix above will fix this issue.
As one of the new features in frame gen where it names files for you and you have to un-checking the File Naming checkbox when create parts ,this is creating an issue for us as sometimes it is not unchecked and so part name does not equal file name,so the second part of code fixes this issue for me thank you.
The code to turn visibility off would work in same way as required for material but in the instance off adding to description we now require it to be invisible for view rep purpose workflow as follows.
  • Find materials I;e; steel/plywood/PVC/rubber
  • create new rep and lock
  • rep is used in dwgs
if have set this search up in the find command box in inventor and it works but is quite slow on large assemblies
Regards
D clunie
Thanks for all yur help on this codeSmiley Very Happy
Message 7 of 9
Curtis_Waguespack
Hi dclunie,
So I've taken what you've said above literally and created a radio button input to allow the user to select Either Steel or Timber as a material, and then apply the description and part number to those parts that are the selected material. But as it is currently written there really isn't a need to choose between the two because they are getting the same treatment. If the steel parts were to get "=<G_L> x <G_W> x <G_T>" for the description and the timber parts were to get "=<G_W> x <G_L> x <G_T>" for the description then it makes sense to choose between the two.
 Here the user is asked to select on or the other materials, but as I mentioned the actual formating of the iProperties is the same, but you could modify that if needed:
'Prompt user to choose from options
Dim booleanParam as Object
booleanParam = InputRadioBox("Select a Material", _
"Steel", "Timber", True, Title := "iLogic")
'Define the open document
'Iterate though the part files in the assembly
'format file name
'set description and part number for steel parts
If booleanParam = True Then
'set description
iProperties.Value(docFName, "Project", "Description") _
iProperties.Value(docFName, "Project", "Part Number") _
Else
'set description and part number for timber parts
booleanParam = False
If iProperties.Material(docFName) = "Timber" Then
'set description
End if
End if
Next
Else
Here is another version, that checks to see if the material is either Steel or Wood and and applies the formatting to all parts having one or the other of those materials:
'format file name
If iProperties.Material(docFName) = "Steel" OR _
'set description
Next
Else
I'll try to get back to the visibility, view rep part of this later (it might be a few days).
 I hope this helps.
Curtis
Message 8 of 9
dclunie
Hi Curtis
Thanks that code works great just what I needed we have multiple material components in our assemblies and now I can push all various descriptions to each of selected components ensuring our boms are nice and clean .
As you mentioned about the visibility it will need to find in the exact way but not altering any iproperties just find all ipts that match certain materials then visibility = off.
There is no rush for this one you have done quite a bit for me already ,many thanks it's good to know that people are out there willing to share there knowledge to help others . Smiley Very Happy
Message 9 of 9
Curtis_Waguespack
Hi dclunie,
See this link for the View Representation rule:
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-set-Design-View-Representation-by-material/td...
I hope this helps.
Curtis
