Inventor Forum
Ilogic or macro
12 REPLIES 12
Message 1 of 13
970 Views, 12 Replies
Ilogic or macro
Not too informed on the coding part, but can anyone give me an idea on how to get my length field and my mass per sq ft field and put the result into a custom field in the BOM? Trying to get gross weight, not the net weight inventor gives by default. Want the weight of the part before any machining would be done to it.
12 REPLIES 12
Message 2 of 13
Cadmanto
Steven,
Is this link what you are looking for?
http://www.inventortales.com/2012/02/sum-of-its-parts-adding-column-values.html
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 13
jtylerbc
Depending on exactly what you're doing (how you're getting those Length and Mass per sq ft values), you may not need any coding at all.  Do you already have these values in your model as Model or User parameters?
If so, you can just check the Export column in the Parameters dialog box, and that will create a custom iProperty with the same name (and value) as the parameter.
Message 4 of 13
in reply to: Cadmanto
But therein lies the problem, the mass field only gives me the mass of the object as is, after finished, while I need it to give me the weight "before" any machining is done, "after" the machining is done 🙂
Would density x length simply be enough? This must work for plates, beams, channels, tubes, etc, so need a common formula I can apply to all parts.
We currently have a field that calculates the net weight and a way to total these up in the parts list, but am unable to get the gross weight before machining. We are getting it to work, but it requires we go into the content center and libraries and put codes and fields into every single part. Time consuming to say the least. Was wondering if anyone good at coding knew a simpler way, a macro or rule one could run instead?
Message 5 of 13
Cadmanto
What about a derived part situation?  One that represents the before and one for the after.
Then you could have each linked and yet still give you the weights you need.
Would that work?
Best Regards,
Scott McFadden
Message 6 of 13
Hey scott.
Thought of that, but we use FG to make oil rigs and sometimes parts need completely finished before work can begin on another part, and really not fond of the idea of having to place and trim all beams just to create a pre-finished model. Plus plates for connectors, etc., and then the 10,000 changes begin and the finished is not even close to the start 🙂
My problem is that LxWxT/density gives me what I need, but of course the length, width and thickness fields for beams, channels, tubes, etc are not labeled the same and beams have 2 thickness fields as web and flange.
That being said was wondering if the density of the material per square foot X length would give me what I need as we already have our custom length fields in the parts.
Message 7 of 13
Cadmanto
Hi Steven,
I getcha.  What about creating an LOD?  Would that work?  But after thinking about it that would still only give you one representation in the BOM I think.  Unless you did a factory file.  I think anyway you go is going to be some what complicated and time consuming.  Smiley Sad
What you might be looking at is making a suggestion in the Inventor IdeaStation
that would add an additional base parameter in the part, that is set by the user.  Meaning the user establish in cases like what you are describing when the base weight is.  Then you would have two weight values.  One as the raw setting and the after machining value.
See the idea I posted and see if it makes sense to you.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Additional-Weight-Parameter-Setting/idi-p/3887006
Best Regards,
Scott McFadden
Message 8 of 13
jtylerbc
This doesn't help you with the plates, but for some of the Frame Generator shapes (angles are the one I confirmed it exists on),  there is a user parameter MAS, which represents Mass per Length.
If you added this parameter to the families currently missing that value, then you could have the FG parts calculate their own pre-machined weight, without any coding.  Instead, you would just add another User Parameter, Gross_Weight.
Gross_Weight could then be defined as:
Gross_Weight = MAS x G_L
Message 9 of 13
mrattray
I think Curtis Waguespack's idea of part LOD's would cover this: http://forums.autodesk.com/t5/Inventor-IdeaStation/Level-of-Detail-for-Parts/idi-p/3822718
Mike (not Matt) Rattray
Message 10 of 13
in reply to: jtylerbc
I'll look into that, thanks. I knew there was a density field which i figured with some math could use to get the gross weight, and maybe inventor already uses the MAS value to get the density. Thanks.
Message 11 of 13
Yah, the MAS field is in all the content center, but is an internal field, not in the parameter list. That's what we are currently doing is adding the MAS field to all the parts in the paramter list to do the calculation. Works good, was just thinking maybe an external ilogic rule could get that value for me, do the calc and place it in a custom field in the BOM. I know with ilogic you can grab internal values, not just parameter values. Thought maybe it would save me the time of adding the paramter MAS to every part.
Message 12 of 13
jtylerbc
Just to be clear, I wasn't proposing that you manually add the MAS parameter to every part you pull from Content Center.
Take the Equal Angle family as an example - for it, the MAS property IS in the parameters of the parts.  I was proposing that the other CC families be edited so the MAS property and the calculation for the gross weight would already be present.  From then on, you wouldn't have to do anything to your CC steel parts to get the gross weight.
Message 13 of 13
Yah, that's what I meant, we are editing the CC family tree table to add the MAS value. Believe me, if I had to do it to every part one by one it would NOT get done 🙂
