Hello, I am pretty new to inventor and iLogic in general, I've just started to experiment...
My aim is to create a flexible subassembly file of a weldment to be used more than once within a top assembly, and then change parameters and features of the various weldments (and of its "part" components) running a rule in the top assemly.
My problem is that I would like to change parameters "freely" (instead of using a preexisting table, like in iParts) and, especially, to be able to modify common feature of all the weldments by modifing one single file without having to replace/regenerate all the weldments in the top assembly.
What I really want is to modify independently multiple istances of the same weldment/parts, but obviously this cannot be done. What's the simplest workaround? Using iParts and iAssemblies and then modifying the table with iLogic with the exact values I want, or generating/placing all the weldments in the top assmebly with a specific rule using "place iLogic component"?
thank you, and sorry if my question is not clear
