Inventor Forum
iLogic MessageBox
3 REPLIES 3
Fleagle8t
10253 Views, 3 Replies
iLogic MessageBox
Hi Folks,
I hope someone can help me out?....
I'm puzzled as to how to get more than one line of text into a Message Box if this is possible.
3 REPLIES 3
jingyi.liu
in reply to: Fleagle8t
For VB language, vbcrlf stands for carriage return, so you could try it as below:
My_Message="Line1"+vbCrLf+"Line2"
MessageBox.Show (My_Message, "My Message")
good luck!
Jingyi Liu
Inventor Product Manager
Hi Fleagle8t,
In addition to jingyi.liu suggestion, you will often see & vblf & used to get the same result:
MessageBox.Show ("Line1" & vblf & "Line2", "My Message")
As as added note, I often like to use a space and underscore in the code to add a line return in the code, for example:
MessageBox.Show ("Some text here used for Line1" _
& vblf & "More text here used for Line2" _
& vblf & "More text here used for Line3" _
& vblf & "" _ 'nothing for line4
& vblf & "More text here used for Line5", "My Message")
Using vbNewLine will work also:
& vbNewLine  & "More text here used for Line2" _
& vbNewLine & "More text here used for Line3" _
& vbNewLine & "" _ 'nothing for line4
& vbNewLine  & "More text here used for Line5", "My Message")
 I hope this helps.
Curtis
Fleagle8t
Thanks Jingyi.liu and Curtis you have really helped me out you're Stars !! ;0)
