Inventor General Discussion
Active Contributor
-ianf-
Message 1 of 6 (320 Views)
Ilogic max character check
320 Views, 5 Replies
12-04-2012 02:45 AM
We use iproperties to describe our parts and have a 40 character limit. Is there any way ilogic could be used to check and possibly warn if an iprop field exceeds 40 characters?
Ian Farmery
Inventor 2010 Pro SP4, Vault Collaboration 2010
HP Z820 Xeon E5-2643 0 @ 3.3Ghz 16.0GB RAM
Nvidia Quadro 5000
Hi -ianf-,
Here is one method:
TitleInput:
Dim MyTitle As String
MyTitle = InputBox("Enter Title" & vblf & "( 40 character limit )", "iLogic", _
 iProperties.Value("Summary", "Title"))
iProperties.Value("Summary", "Title") = MyTitle
currentLength = Len(MyTitle)
If currentLength > 40 Then
MessageBox.Show("Please limit the input to 40 characters or less." & vblf & _
"Current Input Length = " & currentLength, "iLogic ")
Goto TitleInput
Else
End If
 I hope this helps.
Curtis
Valued Mentor
MegaJerk
Message 2 of 6 (296 Views)
Re: Ilogic max character check
12-04-2012 08:28 AM in reply to: -ianf-
Which iProperty field are you using? Do you ever change the field that you fill out or is it consistent across all parts?
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
Active Contributor
-ianf-
Message 3 of 6 (293 Views)
12-04-2012 08:51 AM in reply to: MegaJerk
We populate many iprop fields but it is the "TITLE" and the "DESCRIPTION" fields that sometimes breach the 40 character limit. Each part has a different title/description.
The "TITLE" field is populated with the same characters as the "DESCRIPTION" field. We currently use a line in the rule to
control this;
iProperties.Value("summary", "Title") = iProperties.Value("Project", "Description")
Ian Farmery
Nvidia Quadro 5000
Curtis_Waguespack
Message 4 of 6 (286 Views)
12-04-2012 09:22 AM in reply to: -ianf-
Hi -ianf-,
Here is one method:
TitleInput:
Goto TitleInput
Else
End If
 I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
-ianf-
Message 5 of 6 (237 Views)
01-18-2013 12:27 AM in reply to: Curtis_Waguespack
Thanks for that,
great liitle code which will definatley have a use.   I am trying to build on some of the commands you have used but I am struggling.
Our iprop descriptions/titles are already populated from the parameters using a small code. Basically as the size of the part changes so do the descriptions.  We don't require a description input box.
What I would like to happen is that an ilogic code checks the already inputted description for the character length and bring up a warning if the 40 limit is breached.
For example we have several sheet metal parts that can have many folds. Each fold size ends up in the part descriptions so there is the potential (on complicated pressed parts) to exceed 40 characters.
Ian Farmery
Nvidia Quadro 5000
Curtis_Waguespack
Message 6 of 6 (227 Views)
01-18-2013 07:30 AM in reply to: -ianf-
Hi -ianf-,
Something like this will simply check the iProperty and then alert the user that it exceeds the limit.
I would set this to trigger on the Open and Save events, in order to catch the 40+ striings when a file is acessed or updated.
I hope this helps.
Curtis
MyTitle = iProperties.Value("Summary", "Title")
MessageBox.Show("The Title iProperty currently exceeds the 40 character limit." & vblf & _
MyTitle & " = " & currentLength & " characters" , "iLogic ")
Else
End If
