Inventor General Discussion
waynehelley
Message 1 of 7 (422 Views)
Ilogic - Make drawing view shaded.
422 Views, 6 Replies
01-22-2013 02:03 AM
Is there a line of code that will look at a drawing view and turn shading on?
I have tried
ActiveSheet.View("VIEW1").View.Shaded = True
but it didn't work :smileysad:
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2013
Windows 7 Enterprise, 64-bit
This iLogic code works for a drawing and changes all views in the selected sheet.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' select drawing views on active sheet
Dim oDrawView As DrawingView
For Each oDrawView In oSheet.DrawingViews
'adjust drawing view style
oDrawView.ViewStyle = DrawingViewStyleEnum.kShadedHiddenLineDrawingViewStyle
'OPTIONS TO CHOOSE FROM
' kHiddenLineDrawingViewStyle = 32257
kHiddenLineRemovedDrawingViewStyle = 32258
kShadedDrawingViewStyle = 32259
kShadedHiddenLineDrawingViewStyle = 32261
kFromBaseDrawingViewStyle = 32260
Next
Distinguished Contributor
VdVeek
Message 2 of 7 (409 Views)
Re: Ilogic - Make drawing view shaded.
01-22-2013 03:22 AM in reply to: waynehelley
There was an older post here: http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-code-for-Visual-styles-Shaded-w...
Hope that helps you.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
waynehelley
Message 3 of 7 (380 Views)
01-23-2013 12:01 AM in reply to: VdVeek
Thanks but the post seems to be refering to the Display Style in the modelling environment, whereas I want to change the style of a drawing view.
Wayne Helley
mrattray
Message 4 of 7 (367 Views)
01-23-2013 05:49 AM in reply to: waynehelley
This is from VBA, experiment with it to make it work in iLogic.
DrawingView.ViewStyle = kShadedDrawingViewStyle
I'm not sure how familiar you are with coding in iLogic, but post back if you need more help.
Mike (not Matt) Rattray
VdVeek
Message 5 of 7 (357 Views)
01-23-2013 06:14 AM in reply to: mrattray
Dim oSheet As Sheet
Next
waynehelley
Message 6 of 7 (353 Views)
01-23-2013 06:27 AM in reply to: mrattray
Thanks Mike,
I have been having a play around but haven't had any luck yet.  i though the following may work but Inventor can not recognise 'View Style':
ActiveSheet.View("VIEW1").ViewStyle=kshadedDrawingViewStyle
I get the folliwng error:
Rule Compile Errors in Rule0, in 09090G00105414.idw
Error on Line 1 : 'ViewStyle' is not a member of 'Autodesk.iLogic.Interfaces.ICadDrawingView'.
Wayne Helley
waynehelley
Message 7 of 7 (351 Views)
01-23-2013 06:30 AM in reply to: VdVeek
Thanks VdVeek
Wayne Helley
