Hope I can get some help on some iLogic customization. I have a skeletal part that is set up and works fine iLogically. My issue is I am driving this part with a lot of parameters as well, but I am trying to display the proper dimension of the last rect pattern occurrence (Top of step to floor). I can get it mathmatically close but when I add another step or occurence thru ilogic (input) it changes the last occurrence in the pattern. So when I used a sketch to dimensionally show last step height, but when you add another occurence by input, it makes the one you dimensioned the second to last occurrence so the dimension from the sketch has almost doubled and another occurence (step) placed. So now I need the dimension of the new occurence to the floor. Does anyone have a better process? Or solution?
