Inventor General Discussion
Valued Mentor
MegaJerk
Message 11 of 12 (80 Views)
Re: iLogic Help needed
08-18-2012 09:05 PM in reply to: theo.bot
theo.bot wrote:
Maybe it's easier to use a datamangement tool for this like Vault.
Theo
Agreed. If you're trying to prevent users from working on files that other users may be actively working on, then your best bet would be to go on and grab Vault so that you can incorporate a nice check in / check out into your work flow.
If that isn't your goal, perhaps you can explain in a bit (or a lot) more detail, about what you're trying to do, and why.
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
Active Contributor
gcooper79
Message 12 of 12 (55 Views)
09-03-2012 03:31 AM in reply to: MegaJerk
I agree that vault would solve the issue.  However, the company has not yet installed Vault and the department that has the user issue are not too keen on using Vault anyway.  I think they have solved the problem by  sacking the user anyway :smileywink:
thanks for all your help.
