Inventor Forum
iLogic Hanging at the end of running a set of rule
1 REPLY 1
algypug
231 Views, 1 Reply
I am facing a problem with iLogic.  Whenever a sequence of rules are run, it executes fine and then, just at the end, the model freezes without all the constraints.
To get it to work, you I to just move one part of the assembly and it all snaps back to the correct positions
The problem is that this doesn't update in Configurator, so I need an iLogic solution that would update all the constraints properly after the rules are done so tht the perfect model come out of the sequence.
1 REPLY 1
bretrick30
in reply to: algypug
Try putting the following code at the end of the last rule that runs.
InventorVb.DocumentUpdate()
