I am facing a problem with iLogic. Whenever a sequence of rules are run, it executes fine and then, just at the end, the model freezes without all the constraints.
To get it to work, you I to just move one part of the assembly and it all snaps back to the correct positions
The problem is that this doesn't update in Configurator, so I need an iLogic solution that would update all the constraints properly after the rules are done so tht the perfect model come out of the sequence.
I have attached before and after photos of this..
Try putting the following code at the end of the last rule that runs.
InventorVb.DocumentUpdate()
