Hello everybody,
I'm looking for a way to get the option "copy to flat pattern" automated in iLogic. Is this possible? If yes, how?
Thanks!
Stan
Solved by d182284. Go to Solution.
Hi! I am not sure if iLogic has direct call to do that. But, here is the Inventor API.
PlanarSketch.CopyToFlatPattern() As Boolean
If you set it to True, the sketch will be copied to flat.
Thanks!
I'll post it in the customization folder and hope i get more luck there. I actually didn't notice i posted this in the general disucssion forums, sorry for that.
