Inventor General Discussion
craigzcool
Message 1 of 3 (1,039 Views)
ilogic generate parts list
1039 Views, 2 Replies
10-04-2012 02:34 AM
Hi, I curently have a rule that generates a part list automatically in a drawing. the problem is that I want the rule to be continuisly running but it keeps generating 2,3,5... parts lists. I need an if statment to check if a parts list already exists.
iLogicVb.UpdateWhenDone = True
    On Error Resume Next
    ' Set a reference to the drawing document.    ' This assumes a drawing document is active.    Dim oDrawDoc As DrawingDocument
     oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    ' Set a reference to the first drawing view on    ' the sheet. This assumes the first drawing    ' view on the sheet is not a draft view.    Dim oDrawingView As DrawingView
    oDrawingView = oSheet.DrawingViews(1)
    ' Set a reference to th sheet's border    Dim oBorder As Border
    oBorder = oSheet.Border
    Dim oPlacementPoint As Point2d
    If Not oBorder Is Nothing Then
        ' A border exists. The placement point        ' is the top-right corner of the border.        oPlacementPoint = oBorder.RangeBox.MaxPoint
    Else
        ' There is no border. The placement point        ' is the top-right corner of the sheet.         oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    End If
    ' Create the parts list.    Dim oPartsList As PartsList
    oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
iLogicVb.RunRule("SortPartsList")
Hi craigzcool,
Here's a quick rule that checks for an existing parts list:
Dim oDoc As Inventor.DrawingDocument
oDoc = ThisDoc.Document
'specify the drawing sheet as the first sheet in the collection
oSheet = oDoc.Sheets(1)
Try
Dim oPartslist As PartsList
'set as the first parts list found on sheet 1
oPartslist = oSheet.PartsLists(1)
MessageBox.Show("There is an existing Parts List", "iLogic")
Catch
MessageBox.Show("There is NOT an existing Parts List", "iLogic")
End Try
You could also use an Error check to catch the case where no parts list is found, as in this example:
http://inventortrenches.blogspot.com/2011/02/ilogic-code-for-parts-lists-title.html
 I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 3 (1,031 Views)
Re: ilogic generate parts list
10-04-2012 04:56 AM in reply to: craigzcool
Hi craigzcool,
Try
Catch
End Try
 I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
craigzcool
Message 3 of 3 (1,027 Views)
10-04-2012 05:04 AM in reply to: craigzcool
The code works perfectly!
Thanks :smileyhappy:
