I have upgraded from 2012 to 2014 but there is a smaller list of visual styles for the Ilogc form. I used to set all forms to "iMaginary" but his is not an option in 2014. Is there a way to copy the form visual style from 2012 to 2014?
Solved by Jon.Dean. Go to Solution.
You can use your old iLogic forms in Inventor 2014 but you cannot change the number of Visual Styles in the Form Editor, you will have to use what is available.
Jon
So basically the number of visual styles have been reduced and the ones that are now availible are not as clear as the visual style I picked in 2012.
Is there a reason why the choice is much smaller?
I'm not sure of the reason but they did add two additional form styles.
Maybe they just wanted to clean up the list.
I will log the issue with Development on your behalf.
Jon.
Hi Jon
Any update on this matter as per I'm also loking for more style thant the given one
Yes this really stinks, I just came from 2012 to 2016 and its kind of silly that there are not more form styles! I lost Imaginary. Why can't they just link the windows color styles? Or give us something to make our own?
