Hi folks,
I have a small problem with iLogic forms picture folder. Is there a way of seting the image by the selected tab ?
I want to update the image by the tab selection.
I have tried "if" or "select case" and neither one worked. as I am saying Stair_Properties = True it only makes the tab active. It doesnt indicate if it is selected, here is the code :
If Stair_Properties = True Then Image = "Image 01" End If If Railing_Properties = True Then Image = "Image 02" End If If Riser_Properties = True Then Image = "Image 03" End If 'Select Case Image 'Case Stair_Properties 'Image = "Image 01" 'Case Railing_Properties 'Image = "Image 02" 'Case Riser_Properties 'Image = "Image 03" 'End Select
Thanks ...
Could you just re-order the contents of your form? Drag the image down into the Tab Group you've called "Stair_Properties".
Do the same for the other two tabs, then switching tabs will display the appropriate image and related data fields.
