Inventor Forum
ilogic form for properties
10 REPLIES 10
Message 1 of 11
amasva
3245 Views, 10 Replies
Hi
I have made a Ilogic form that will help us filling out the properties to a drawing. But there is something wrong, and I can't understand what.
If I starts a new drawing from the template, insert a base view and save the drawing. Then I hit the form button in the ilogic browser and gets a error. See attached jpg. If I close the drawing and open it again the form opens up fine.
Attached is also the drawing template with the form "IDW properties"
If I starts a new drawing and hit the form button before insert a base view everything is fine. When I inserts a base view the form stops working...
Asle
Asle Martin Svastuen
Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
HP EliteBook 8560w
Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
16GB RAM
Windows 7 X64 SP1
10 REPLIES 10
Message 2 of 11
ravikmb5
in reply to: amasva
No problems HERE
working Fine here
i also tried your idw
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Message 3 of 11
amasva
in reply to: ravikmb5
Hi
Did you save the idw in your template folder and star a new idw? The problem appears when I start a new idw from template and insert a master view. If I, after inserting the master view, save the idw close and reopen the form is working. Problem is that I don't wont to close and reopen every new drawing before I can use the form...
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
Message 4 of 11
amasva
Hi. Do you use the form your form in idw or only in iam/ipt? The form that I have made is working for iam/ipt but not in idw..
The problem occurs when I inserts a base view... Is it by chance possible to get a copy of your idw with the form you are using? This so I can test and see if this gives me the same error?
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
Message 5 of 11
ravikmb5
in reply to: amasva
No i am using the form only in iam,ipt
Not in idw
i have linked my iam & ipt properties to the Title Block
Ravi Kumar MB,
Message 6 of 11
amasva
in reply to: amasva
Hi
We also copy properties from the model to the idw, but some field we whish to fill out in the idw. For example: designer and approved. Have anyone made a form to fill out properties in idw?
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
Message 7 of 11
ravikmb5
in reply to: amasva
Hmmmmmm
You are using forms which are in document
Convert it into Global Forms
This should Work
Ravi Kumar MB,
Message 8 of 11
amasva
Hi
Have tried global also, with the same result..
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
Message 9 of 11
ravikmb5
in reply to: amasva
i have seen there are some custom properties in ur idw
have u copied ur custom properties to all ur idws
if not
use design assistant and copy those custom properties to entire idw which ur using
or
create an rule in ilogic to create custom properties
i hope this will help
No problems here running ur idw form
Ravi Kumar MB,
Message 10 of 11
amasva
Hi
It seems as Vault Collaboration may be causing this problem. If I use a project file that are "single user" the "Form" is working fine. If I use a project file that is "Vault" the "Form" stops working after creating a new view. See video on youtube: http://www.youtube.com/watch?v=pPdIRpVpHuc
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
Message 11 of 11
amasva
in reply to: amasva
The same thing is happening when I tries to run a rule manually. The same rule is triggered by a event trigger (before save), this works fine.. Strange.. The problem occur only after placing a base view or creating a new view. If I save, close and reopen the drawing everything works fine.. The I create a new view and gets the same error.. Also when I open a drawing from Vault without checking it out the Form is working, then I check it out and the Form stops working.. I have installed Inventor and Vault on two computers (One XPx86 and one WIN7x64) and they both have the same problem.
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
