Inventor General Discussion
Curtis_Waguespack
Message 11 of 14 (880 Views)
Re: ilogic form dropdown?
08-02-2012 06:32 AM in reply to: mcgyvr
Hi mcgyvr,
You're correct. There isn't a way to point the form to the iProperty and have a list, at least not that I'm aware of.
Therefore we need to use the paramter list in the form, and hand the value from the paramter to the iProperty. I used a model parameter in the example, but you could also use a user parameter if a model parameter would not work.
The iLogic forms have some limitations compared to standard VB userforms, but I'm not sure why certain option are included / not included for the controls.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
mcgyvr
Message 12 of 14 (873 Views)
08-02-2012 06:37 AM in reply to: Curtis_Waguespack
Sure would have made life easier..
Autodesk needs more forward thinkers or better "brainstorming" sessions.
blah I'll just stick with the ugly inputbox rules I've already got..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
*Pro
jletcher
Message 13 of 14 (862 Views)
08-02-2012 12:59 PM in reply to: rhasell
rhasell
use row and place the perameters in there if i put 3 there would be 3 columns and so on. Here is a pic. and don't give me credit some one showed me..
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Contributor vex
Valued Contributor
vex
Message 14 of 14 (56 Views)
10-16-2014 02:32 PM in reply to: Curtis_Waguespack
I'm trying to do a similar code that dynamically updates a drop down menu with the selection of a primary criteria from a drop down menu.  Looking at the Parameters menu it works flawlessly.  When attempting to do it via a Form it doesn't work.  I don't get the second menu as a drop down but only as a text field for input.  What am I missing?
(Inventor Pro 2015)
edit: NVM, had to re-add the field after the coding.
