I want to replace view labels in drawings with sketch symbols to get a different appearance to my drawings. (As far as i know it is not possible to change the appearance of the standard view label.) See attached snap of my desired view label.
I have used ilogic on several occasions successfully but im not experienced at all.
The way I see this working is for a sketch symbol to be inserted below a view when it is created,the standard view label being omitted & the Scale/Name/Sheet details linking to the sketch symbol through parameters.
If anyone can point me in the right direction on this one i would be greatful.
Cheers,
Unless someone has some brilliant idea on how to do this simply, it would be very difficult, cumbersome, and unreliable through iLogic (at least the way I picture it working). You may have a better chance of getting one of those brilliant ideas from one of the API gurus if you post in the Inventor Customization forum.
Yes I can imagine it can be done through i logic but dont know anywhere near enough about writing code to produce it in ilogic.
It wouldnt be worth looking into it for me haha.
Inventor 2020 perhaps.......?!?!?! haha
SyntaxEditor Code Snippet
This should get you started. It will insert a different sketch symbol based on the type of view it is. (I have section, detail, base and projected view set up already. Might not be a great way to get it done and this is not done yet (I want to attach each tag to its respective view.). I have been able to piece alot of code together from people on these forums so i thought i would give a little back. This code is taken from multiple posts from other users.
Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document oModelDoc = ThisDoc.ModelDocument Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView Dim oSymbol As SketchedSymbol Dim oSymbols As SketchedSymbols ViewLetter = New String(){"A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","X","W","Y","Z"} Dim ViewCount = 0 oSheets = oDoc.Sheets Dim view_asso_draft = 10506 Dim view_auxillary = 10499 Dim view_custom = 10498 Dim view_default = 10497 Dim view_detail = 10502 Dim view_draft = 10505 Dim view_OLE = 10500 Dim view_overlay = 10507 Dim view_projected = 10504 Dim view_section = 10503 Dim view_standard = 10501 For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oSymbol In oSheet.SketchedSymbols If oSymbol.Definition.Name = "TTLs" Then oSymbol.Delete Else If oSymbol.Definition.Name = "TTL" Then oSymbol.Delete Else If oSymbol.Definition.Name = "DET TTL" Then oSymbol.Delete Else If oSymbol.Definition.Name = "SEC TTL" Then oSymbol.Delete End If Next For Each oView In oViews 'Set label as visible oView.ShowLabel = False 'check view types If oView.ViewType = view_detail Then oView.Name = ViewLetter(ViewCount) ViewCount = ViewCount + 1 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("DET TTL") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view name 'set the position for the sketched symbol to be inserted 'and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.75 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) '------------------------------------------------------------------------------------------------------ Else If oView.ViewType = view_section Then oView.Name = ViewLetter(ViewCount) ViewCount = ViewCount + 1 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("SEC TTL") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name 'set to view name 'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view scale 'set the position for the sketched symbol to be inserted ' and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.75 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) '------------------------------------------------------------------------------------------------------ Else If oView.ViewType = view_standard Then 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("TTL") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name 'set to view name 'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view scale 'set the position for the sketched symbol to be inserted ' and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.5 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) '------------------------------------------------------------------------------------------------------ Else If oView.ViewType = view_projected Then 'This places a sketched symbol Dim oSymDef As SketchedSymbolDefinition 'define the sketch symbol to be inserted oSymDef = oDoc.SketchedSymbolDefinitions.Item("TTLs") 'set a string array with values for the prompted entries found in the symbol Dim sPromptStrings(1) As String sPromptStrings(0) = oView.Name 'set to view name 'set to view scale sPromptStrings(1) = oView.ScaleString 'set to view scale 'set the position for the sketched symbol to be inserted ' and spaced off of the selected view center Dim oPosition As Point2d: oPosition = oView.Center oPosition.y = oPosition.y - (oView.Height / 1.5 + 0.6) 'insert the sketched symbol and set the prompted entries oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings) End If Next Next
