Inventor Forum
iLogic for Sketch Symbols
4 REPLIES 4
shmartin89
1220 Views, 4 Replies
I want to replace view labels in drawings with sketch symbols to get a different appearance to my drawings. (As far as i know it is not possible to change the appearance of the standard view label.) See attached snap of my desired view label.
I have used ilogic on several occasions successfully but im not experienced at all.
 The way I see this working is for a sketch symbol to be inserted below a view when it is created,the standard view label being omitted & the Scale/Name/Sheet details linking to the sketch symbol through parameters.
If anyone can point me in the right direction on this one i would be greatful.
Cheers,
4 REPLIES 4
over a year later, but i would also like some advise as to how to do this
Stephen Gibson
View stephen gibson's profile on LinkedIn
mrattray
in reply to: stephengibson76
Unless someone has some brilliant idea on how to do this simply, it would be very difficult, cumbersome, and unreliable through iLogic (at least the way I picture it working). You may have a better chance of getting one of those brilliant ideas from one of the API gurus if you post in the Inventor Customization forum.
Mike (not Matt) Rattray
shmartin89
in reply to: mrattray
Yes I can imagine it can be done through i logic but dont know anywhere near enough about writing code to produce it in ilogic.
It wouldnt be worth looking into it for me haha.
Inventor 2020 perhaps.......?!?!?! haha
sstyxx
in reply to: shmartin89
SyntaxEditor Code Snippet
This should get you started.  It will insert a different sketch symbol based on the type of view it is. (I have section, detail, base and projected view set up already.  Might not be a great way to get it done and this is not done yet (I want to attach each tag to its respective view.).  I have been able to piece alot of code together from people on these forums so i thought i would give a little back.  This code is taken from multiple posts from other users.
Dim oDoc As DrawingDocument:  oDoc = ThisDoc.Document
oModelDoc = ThisDoc.ModelDocument
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
ViewLetter = New String(){"A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","X","W","Y","Z"}
Dim ViewCount = 0
oSheets = oDoc.Sheets
Dim view_asso_draft = 10506
Dim view_auxillary = 10499
Dim view_custom = 10498
Dim view_default = 10497
Dim view_detail = 10502
Dim view_draft = 10505
Dim view_OLE = 10500
Dim view_overlay = 10507
Dim view_projected = 10504
Dim view_section = 10503
Dim view_standard = 10501
For Each oSheet In oSheets
oViews = oSheet.DrawingViews
For Each oSymbol In oSheet.SketchedSymbols
If oSymbol.Definition.Name = "TTLs" Then
oSymbol.Delete
Else If oSymbol.Definition.Name = "TTL" Then
oSymbol.Delete
Else If oSymbol.Definition.Name = "DET TTL" Then
oSymbol.Delete
Else If oSymbol.Definition.Name = "SEC TTL" Then
oSymbol.Delete
End If
Next
    For Each oView In oViews
           'Set label as visible
        oView.ShowLabel = False
        'check view types
        If oView.ViewType = view_detail Then
            oView.Name = ViewLetter(ViewCount)
            ViewCount = ViewCount + 1
            'This places a sketched symbol
            Dim oSymDef As SketchedSymbolDefinition
            'define the sketch symbol to be inserted
            oSymDef = oDoc.SketchedSymbolDefinitions.Item("DET TTL")
    'set a string array with values for the prompted entries found in the symbol
    Dim sPromptStrings(1) As String
    sPromptStrings(0) = oView.Name'set to view scale
    sPromptStrings(1) = oView.ScaleString 'set to view name
    'set the position for the sketched symbol to be inserted
    'and spaced off of the selected view center
    Dim oPosition As Point2d: oPosition = oView.Center
    oPosition.y = oPosition.y - (oView.Height / 1.75 + 0.6)
    'insert the sketched symbol and set the prompted entries
    oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings)
        Else If oView.ViewType = view_section Then
            oSymDef = oDoc.SketchedSymbolDefinitions.Item("SEC TTL")
    sPromptStrings(0) = oView.Name 'set to view name 'set to view scale
    sPromptStrings(1) = oView.ScaleString 'set to view scale
    ' and spaced off of the selected view center
        Else If oView.ViewType = view_standard Then
            oSymDef = oDoc.SketchedSymbolDefinitions.Item("TTL")
    oPosition.y = oPosition.y - (oView.Height / 1.5 + 0.6)
        Else If oView.ViewType = view_projected Then
            oSymDef = oDoc.SketchedSymbolDefinitions.Item("TTLs")
    End If
    Next
Next
