Hi, I am currently designing a heat exchanger and want to adjust the number of water channel using iLogic. The number of channels to be active is based on the channel dimensions, and is calculated in my excel spreadsheet, but up to a maximum of 19. This is stored in the parameter "no_channel". Each channel is a seperate feature (extrusion) and named from "Channel 1" though "Channel 19".
My idea of doing this automation was to have iLogic suppress all the features, and then doing a closed loop to unsuppres the features I want active:
Feature.IsActive("Channel 1") = False Feature.IsActive("Channel 2") = False . . . Feature.IsActive("Channel 19") = False For i = 1 To no_channel Feature.IsActive("Channel"(i)) = True Next
However, this gives me the following error:
Error in rule: Number of channels, in document: Radiator fin side.ipt
Feature.IsActive: No feature found with the name: "h".
I am not experienced with iLogic at all, so any help as well as suggestions on improving the efficieny of my automation would be appreciated (eg. having all features active and simply suppressing the unwanted channels).
Best regards
Solved by jianbinlin. Go to Solution.
Try this. When i = 1, "Channel "& i returns "Channel 1"
Feature.IsActive("Channel "& i) = True
@jianbinlin wrote:Try this. When i = 1, "Channel "& i returns "Channel 1"
thank you Jianbinlin for this great tip, i have also a question!
what if we have 2 identifiers in the name for example if the name of component is like this " Solid:3-2" and we have tow variables like "i" and "j" and we would like to change the components state within tow "for" loops ???
the code below did not worked with this configuration because inventor considers "dash" as subtraction sign. i have also tried to change dash sign to UnderLine but not worked. in this case aslo, "i_j" was not correct expression.
so... how should i write this code??
for i=1 to 5 for j=2 to 3 Component.IsActive("Solid:"& i-j) = False next next
Regards
Reza
Try this 🙂
For i = 1 to 5 For j = 2 to 3 Component.IsActive("Solid:"& i & "-" & j) = False Next Next
This should resolve from
Solid:1-2
to
Solid:5-3
I am trying to search for a method to isolate/split common text/prefix instead of an index value, from a feature name so I can suppress
all features with that same prefix text. See below.
Feature Names e.g's:
"PREFIX SOMETHIING"
"PREFIX SOMETHING ELSE"
"PREFIX SOMETHING ELSE AGAIN"
"EXTRUDE1"
"EXTRUDE2"
SyntaxEditor Code Snippet
Dim oDoc As PartDocument oDoc = ThisApplication.ActiveDocument Dim oFeatures As PartFeatures oFeatures = oDoc.ComponentDefinition.Features Dim oFeature As PartFeature For Each oFeature In oFeatures If oFeature.Name.Contains("PREFIX") Then Feature.IsActive("not sure what to put in here?") = False End If Next
I can't seem to manipulate the "Feature.IsActive()" syntax to apply to only the features that contain the text "PREFIX"?
Any help would be greatly appreciated.
on my opinion, if your "if" statement is true programmatically, you do not need to place any especial command there. and it will be executed as well. but actually I am not sure that the below snippet is true or not.
Thanks for the quick response Reza!
The Feature.Name.Contains("PREFIX") is a simpler method of extracting the common text which
appears in the Features I want to isolate and suppress. The other method is using the trim function: Left( Feature.Name,6) = "PREFIX"
BUT...................YES you are absolutely right, I don't need that condition to then suppress a named feature.
But I do want to achieve the same name split of the text as I have done in the ABOVE EXAMPLE
but using this code snippet "Feature.IsActive("featurename") = False" to get my result.
I somehow need the ("featurename") in the above snippet to represent any feature.name that contains the text "PREFIX".
Apologies if I am not explaining it well, but I am simply trying to avoid having to
specify every feature name in full that I want to toggle the suppression on
E.g.
Feature.IsActive("PREFIX - FEATURE SIDE") = False"
Feature.IsActive("PREFIX - FEATURE TOP") = False"
Feature.IsActive("PREFIX - FEATURE RHS") = False"
Feature.IsActive("PREFIX - FEATURE LHS") = False"
Hope this clarifies what I am trying to achieve.
Find attached a part with Rule example that suppresses Features when each name is specified.
I believe you understand what I am trying to achieve.
Thanks in advance for your time on this. Much appreciated.
Cheers
Forbillian
Hey Robert.
I found a solution based on this code I found in an article titled: 'Suppressing all chamfer or fillets with iLogic' By Xiaodong Liang
doc = ThisDoc.Document oDef = doc.ComponentDefinition Dim oEachF As PartFeature For Each oEachF In oDef.Features If oEachF.Name.Contains("PREFIX") Then oEachF.Suppressed = True End If Next
See attached part which shows the example & includes another option of text within a different feature name.
Just want to shout out my appreciation to Robertlee Wheatley for your rapid responses and your time and inspiring me
to find a solution. If you have any other suggestions on this scenario please feel free to let us know.
Hi @balkeev.tim
See this example.
I hope this helps.
Curtis
' Get the active document. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'Iterate through all of the occurrences Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef) oDoc = oOccurrence.Definition.Document oDef = oDoc.ComponentDefinition Dim oEachF As PartFeature For Each oEachF In oDef.Features If oEachF.Name.Contains("Fillet") Then oEachF.Suppressed = True End If Next Next
