I have an ilogic rule to open an existing excel file template and export the inventor parameters into it. I am trying to find a way to then save the excel file as a different filename. This way the original template can stay unmodified. I have found the GoExcel.save command but is there some sort of GoExcel.saveas(filename, filepath) command?
Solved by Curtis_Waguespack. Go to Solution.
Hi andyflorence6444,
This example might help:
http://inventortrenches.blogspot.com/2012/06/create-new-excel-file-with-ilogic.html
Also see this link:
I hope this helps.
Curtis
Thanks Curtis!,
Those links gave me the information I needed. I can now run ilogic which will automatically open a template, save it as a different unique file name (which it derives), and export all the parameters into it.
