Inventor General Discussion
Valued Contributor
jamjumpin
Message 1 of 12 (756 Views)
iLogic Excel date problem
756 Views, 11 Replies
01-07-2013 07:15 AM
I want iLogic to look up todays date in an excel file and then pull information from that row.
The problem I have is that it doesn't seem to like / or -  so I am not sure how to format the date.
How would I format my date in Excel so that it matches the wway Inventor stores it in iproperties>Project>Creation Date?
Any help would be much appreciated.
Inventor 2013
DwgNum = iProperties.Value("Custom", "Dwg Number")
Client = iProperties.Value("Project", "Vendor")
Description = iProperties.Value("Project", "Description")
DrawingType = iProperties.Value("Custom", "Drawing Type")
author = iProperties.Value("Summary", "Author")
Date2 = iProperties.Value("Project", "Creation Date")
i = GoExcel.FindRow("C:\Users\jwilloughby\Desktop\Drawing_Log_2004.xls", "2013", "TEST", "=", Date2)
DwgNum = GoExcel.CurrentRowValue("DWG #")
Description = GoExcel.CurrentRowValue("DESCRIPTION")
Client= GoExcel.CurrentRowValue("COMPANY")
DrawingType= GoExcel.CurrentRowValue("DRAWING TYPE")
author= GoExcel.CurrentRowValue("DRAWN BY")
iProperties.Value("Custom", "Dwg Number") = DwgNum
iProperties.Value("Project", "Vendor") = Client
iProperties.Value("Project", "Description") = Description
iProperties.Value("Custom", "Drawing Type") = DrawingType
iProperties.Value("Summary", "Author") = author
iLogicVb.UpdateWhenDone = True
Hi jamjumpin,
Here's an example rule. Note if you get an error from Copy and Pasting from this forum, try the attached *.txt file.
I hope this helps.
Curtis
'define the XLS to look at
myXLS = "U:\iLogic examples\Excel Date lookup.xlsx"
GoExcel.Open(myXLS, "Sheet1")
'create an array list to hold found values
Dim myArrayList As New ArrayList
'look at the first 1000 rows of the Excel file
For rowCheck = 2 To 1000
'read the value of the column A
Dim myCell As Double
myCell = GoExcel.CellValue("A" & rowCheck)
'format the found value as a date
Dim myDate As DateTime
myDate = Date.FromOADate(myCell)
'set the current date from the computer system date
Dim curDate As String
curDate = DateString
'compare the found value to the current date
If myDate = curDate Then
'get the description
sDescription = GoExcel.CellValue("B" & rowCheck)
'add the description to the list
myArrayList.add(sDescription)
End If
Next
myName= ThisApplication.GeneralOptions.UserName
'ensure that the current date was found (and added to the array list)
If myArrayList.Count = 0 Then
MessageBox.Show("The current date was not found in the Excel file." , "iLogic")
Else
'present the list to the user
myDesc = InputListBox("Yo, " & myName & " select one of these bad boys!", myArrayList, myArrayList.Item(0), "iLogic", "Selection List")
'present the result
MessageBox.Show("You selected: " & myDesc, "iLogic")
End If
Curtis_Waguespack
Message 2 of 12 (749 Views)
Re: iLogic Excel date problem
01-07-2013 07:36 AM in reply to: jamjumpin
Hi jamjumpin,
I don't see a reference to a date in your example code. Could you post what you've tried so far?
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
jamjumpin
Message 3 of 12 (748 Views)
01-07-2013 07:43 AM in reply to: Curtis_Waguespack
Sorry I just updatead it.
This code doesn't work anyway, it says "Invalid cast from 'DateTime' to 'Double'."
Valued Contributor
jamjumpin
Message 4 of 12 (745 Views)
01-07-2013 07:47 AM in reply to: jamjumpin
Ultimately I want it to find all the references to todays date and display the information from the cells next to it so you can choose which is the correct one.
i.e.
Column 1 is date
COlumn 2 is description
It finds all the dates that match in column 1 and then shows a multivalue box with the corresponding info from Column 2.
When the user picks a value from the multivalue list that is the row it then reads all teh infon from.
Is this even possible in iLogic?
Curtis_Waguespack
Message 5 of 12 (734 Views)
01-07-2013 09:54 AM in reply to: jamjumpin
Hi jamjumpin,
I hope this helps.
Curtis
	End If
Next
Else
'present the result
End If
Valued Contributor
jamjumpin
Message 6 of 12 (722 Views)
01-07-2013 11:47 AM in reply to: Curtis_Waguespack
Thank you very much, I can probab;y use this to trigger the other functions I need it to do.
Valued Contributor
jamjumpin
Message 7 of 12 (721 Views)
01-07-2013 11:50 AM in reply to: jamjumpin
It didn't work at first, and this may be help to anyone else having the problem.
My excel was formatted in the international style of date rather than the USA one.
New Member
SHoffmeyer
Message 8 of 12 (713 Views)
01-07-2013 12:28 PM in reply to: jamjumpin
If it helps, rather than grab it from Excel, you can just use DateString to insert today's date, sort of like:
iProperties.Value("Custom", "DATE")=DateString
This would show up in the format 01-07-2013.  I know it's not the way you were trying to do it, but it might save you some headache in the future.
Scott Hoffmeyer
Inventor Pro 2013 - SP1.1
Dell Precision M6500
i7 CPU Q 820 @1.73GHz
NVIDIA Quadro FX 2800M
Valued Contributor
jamjumpin
Message 9 of 12 (707 Views)
01-07-2013 12:34 PM in reply to: SHoffmeyer
The date is being discarded, it's purely for refernce to grab other info from the Excel sheet.
Valued Contributor
jamjumpin
Message 10 of 12 (702 Views)
01-07-2013 12:38 PM in reply to: Curtis_Waguespack
Thank you, the code seems to work now I've added some extra stuff to the end. I have a few questions.
How do I get it to match the international form of the date instead of the US one? As in dd/mm/yyyy
Is there a way to just read the excel file instead of using the open command? iEverytime I run the command I get the following message, even when it isn't open:
Drawing_Log.xls is already open. Reopening will cause any changes you made to be discarded. Do you want to reopen Drawing_Log.xls?
 Is there a way to stop it asking the following message at the end of the rule too?
Do you want to save the changes you made to 'Drawing_Log.xls'?
The final thing is that sometimes I get the following error when I run the rule. If I don't change anything and run the rule again it works fine. Any ideas?
Error in rule: Rule3, in document: New Drawing iLogic.idw
Object reference not set to an instance of an object.
Once again, thanks so much!
