Inventor Forum
iLogic Error "the unit name is not valid in Inventor"
4 REPLIES 4
phillip.shields
1527 Views, 4 Replies
I'm getting a strange error with my iLogic code running parameters in my assembly.  When I have one "if....then..." my rule runs fine. Even two statements work.  But for some reason when I get to a certain number of statement I get an error: I've attached some sample code and snapshots of my error screens.
If FLANGE_STYLE_BOTTOM = "2in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="6"
Parameter("RD FLANGE:1", "BC")="4.75"
Parameter("RD FLANGE:1", "HOLE_SIZE")=".75"
Parameter("RD FLANGE:1", "NUB_HOLE")="4"
Else If FLANGE_STYLE_BOTTOM="3in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="7.5"
Parameter("RD FLANGE:1", "BC")="6"
Else If FLANGE_STYLE_BOTTOM="4in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="9"
Parameter("RD FLANGE:1", "BC")="7.5"
Parameter("RD FLANGE:1", "NUB_HOLE")="8"
Else If FLANGE_STYLE_BOTTOM="5in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="10"
Parameter("RD FLANGE:1", "BC")="8.5"
Parameter("RD FLANGE:1", "HOLE_SIZE")=".875"
Else If FLANGE_STYLE_BOTTOM="6in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="11"
Parameter("RD FLANGE:1", "BC")="9.5"
Else If FLANGE_STYLE_BOTTOM="8in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="13.5"
Parameter("RD FLANGE:1", "BC")="11.75"
Else If FLANGE_STYLE_BOTTOM="10in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="16"
Parameter("RD FLANGE:1", "BC")="14.25"
Parameter("RD FLANGE:1", "HOLE_SIZE")="1"
Parameter("RD FLANGE:1", "NUB_HOLE")="12"
Else If FLANGE_STYLE_BOTTOM="12in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="19"
Parameter("RD FLANGE:1", "BC")="17"
Else If FLANGE_STYLE_BOTTOM="14in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="21"
Parameter("RD FLANGE:1", "BC")="18.75"
Parameter("RD FLANGE:1", "HOLE_SIZE")="1.125"
Else If FLANGE_STYLE_BOTTOM="16in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="23.5"
Parameter("RD FLANGE:1", "BC")="21.25"
Parameter("RD FLANGE:1", "NUB_HOLE")="16"
Else If FLANGE_STYLE_BOTTOM="18in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="25"
Parameter("RD FLANGE:1", "BC")="22.75"
Parameter("RD FLANGE:1", "HOLE_SIZE")="1.25"
Else If FLANGE_STYLE_BOTTOM="20in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="27.5"
Parameter("RD FLANGE:1", "BC")="25"
Parameter("RD FLANGE:1", "NUB_HOLE")="20"
Else If FLANGE_STYLE_BOTTOM="24in 150 BFV" Then
Parameter("RD FLANGE:1", "OD")="32"
Parameter("RD FLANGE:1", "BC")="29.5"
Parameter("RD FLANGE:1", "HOLE_SIZE")="1.375"
Else If FLANGE_STYLE_BOTTOM="8in SHICK BFV" Then
Parameter("RD FLANGE:1", "BC")="9.75"
Parameter("RD FLANGE:1", "HOLE_SIZE")=".5"
Else If FLANGE_STYLE_BOTTOM="12in SHICK BFV" Then
Parameter("RD FLANGE:1", "OD")="15"
Parameter("RD FLANGE:1", "BC")="13.75"
Else If FLANGE_STYLE_BOTTOM = "16in SHICK BFV" Then
Parameter("RD FLANGE", "OD") = "19"
Else If FLANGE_STYLE_BOTTOM="20in SHICK BFV" Then
Parameter("RD FLANGE:1", "OD")="23"
Parameter("RD FLANGE:1", "BC")="21.75"
Else If FLANGE_STYLE_BOTTOM="2000 AIRLOCK" Then
Parameter("RD FLANGE:1", "OD")="17"
Parameter("RD FLANGE:1", "BC")="15.5"
Parameter("RD FLANGE:1", "HOLE_SIZE")=".625"
End If
4 REPLIES 4
pcrawley
in reply to: phillip.shields
This looks like a good opportunity to try out the "Select Case" statement.
There may be a limit to the number of Else If's.  I haven't yet hit the limit of Select Case.
Select case FLANGE_STYLE_BOTTOM
Case "2in 150 BFV" Parameter("RD FLANGE:1", "OD")="6" Parameter("RD FLANGE:1", "BC")="4.75" Parameter("RD FLANGE:1", "HOLE_SIZE")=".75" Parameter("RD FLANGE:1", "NUB_HOLE")="4" Case "3in 150 BFV" Parameter("RD FLANGE:1", "OD")="7.5" Parameter("RD FLANGE:1", "BC")="6" Parameter("RD FLANGE:1", "HOLE_SIZE")=".75" Parameter("RD FLANGE:1", "NUB_HOLE")="4" Case "4in 150 BFV"
End Select
Peter
MegaJerk
I suspect that it has something to do with this bit :
Looks like you dropped off the occurrence name ID. If so, it should probably be :
Parameter("RD FLANGE:1", "OD")= "19"
Else If FLANGE_STYLE_BOTTOM = "20in SHICK BFV" Then
Also, assuming that your parameter 'OD' is not a text parameter, you could leave off the quotes, making your code look something like :
Parameter("RD FLANGE:1", "OD")= 19
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
phillip.shields
in reply to: pcrawley
Thank you for the quick response but I think I found my problem. If you look back the original code I posted in line 91 of my code right before my "16in SHICK BFV" line. the occurence "NUB_HOLE" = "12. I FORGOT MY OTHER QUOTATION MARK. I will be using that select case though. I feel like that may come in handy.
phillip.shields
in reply to: MegaJerk
Thank you  for your response. In the process of taking off all of my quotation marks I found the problem. I was missing a second quote after my 12. From now on I will just leave them off of numbers.
