Hello everyone,
When I run the iLogic rule I wrote, there is a error box pop-up. The ilogic rule worked for a while but after we tried to load in a xml file the error started showing up. I have also attached the simple rule I have for the "parameter" I was wondering if anybody know I could I fix this. Thank you!
Sincerely,
Sophia
Solved by wimann. Go to Solution.
Matt is right. More information would be beneficial. However, if I had to guess:
Am I right when I assume that you set this up with User Parameters first? Meaning that you set up E_Length, thermowellLength, and Lagwhateveritwascalled in the assembly and pushed those parameters to the parts? Now you've added a spreadsheet that runs E_Length and the others? So your E_Length parameter is set to equal the E_Length input in the spreadsheet? I guess one thing worth mentioning that is probably not the issue would be does the parameter in your spreadsheet have the same name as the parameter in your assembly? I doubt that it is and I'm not testing any of this while I'm thinking about it but I would imagine that if your spreadsheet and your assembly both had exactly "E_Length", that that could cause problems. If so, I'd rename the parameter in the assembly to something like "E_Length1". If that is not it, I would imagine that somewhere along the lines, inventor is having trouble with updating your parts/assembly while bouncing the parameter from the spreadsheet, into a user param, and then down into the part file. I would suggest you get rid of the user parameter. When you import a spreadsheet, the parameters are automatically created and immediately available. I would just use those parameters and skip the assembly user parameters all together. Your iLogic code might look something like this:
Parameter("myPart:1","myParam1") = mySpreadsheetParam1
'mySpreadsheetParam1 being read directly from the spreadsheet
Then again, I could have this whole thing wrong and it could be something entirely different.
Hope this helps!
EDIT: I made a quick assembly and tested all of the above. Had no issues with any of it. Having a pre-existing user param with a conflicting name doesn't cause a problem. The spreadsheet overrides the user param and deletes it. Making a "middle man" parameter (if you will) doesn't cause an issue. The parameter was passed down seamlessly.
So it looks like we need your files lol.
No problem. If it doesn't end up working out, see if you can recreate the problem in a simple (non-confidential) assembly using some dummy parts. I couldn't recreate the problem with the information you gave and experiencing the issue makes it muuuuuuuuch easier to resolve.
