Hey quick question what is the command line to place a part in current view representation (iso view)
ViewOrientationTypeEnum.kCurrentViewOrientation doesn't work, it just creates a default base view...
oSheet.DrawingViews.AddBaseView(OModel,oPoint4, ViewScale ,ViewOrientationTypeEnum.kCurrentViewOrientation, DrawingViewStyleEnum .kShadedDrawingViewStyle)
Greetz
Provo
Solved by VdVeek. Go to Solution.
Quick answer: Did you looked at the api help under ViewOrientationTypeEnum Enumerator ?
kIsoBottomLeftViewOrientation | 10762 | Isometric -- Bottom Left View. |
kIsoBottomRightViewOrientation | 10761 | Isometric -- Bottom Right View. |
kIsoTopLeftViewOrientation | 10760 | Isometric -- Top Left View. |
kIsoTopRightViewOrientation | 10759 | Isometric -- Top Right View. |
kSavedCameraViewOrientation | 10766 | Saved camera View. |
But there is more to choose from. Otherwise you need to give more information of the problem.
Rob.
