I am currently using Autodesk Inventor Professional 2012.
I'm looking for an iLogic code which I can run in my Assembly File which will suppress any component that is not the selected color.
I thought it would go somewhat along the lines of:
If Component.Color()="Red" Then
Component.IsActive() = True
Else Component.IsActive()= False
Next
Which gives errors because I'm not defining the name of each individual component.So I assume I need a way to tell it to procedurally check the color of each component, which is where I'm stumped.
The application is my assembly has multiple isolated systems in the same assembly, and I'm trying to create a Level of Detail for each Isolated system within the assembly, without having to suppress each component one at a time.
Any help is appreciated, thank you
Try this.
I use it all the time for tasks that involve running through an assembly and "doing things" to the components. I'd love to take credit for it, but it's come from a variety of sources over time. So thanks to everyone!
Look in the comments for clues. If you run it "as is" on an assembly, it'll give you a message box that reads the Part Number of each component.
Peter
fmgr = ThisApplication.Filemanager For Each file In fmgr.files doc = ThisApplication.Documents.ItemByName (file.fullfileName) compdef = doc.ComponentDefinition If (doc.documenttype = 12291) Then 'Found an ASSEMBLY For Each occ In compdef.Occurrences If (occ.definition.type = 83886592) Then 'Found a PART 'Add whatever you like here for the PART file 'Remember to add the occ.Name into everything to catch the part file itself 'If you forget it, you'll get the host Assembly MessageBox.Show("Part name: " & iProperties.Value(occ.Name, "Project", "Part Number")) End If Next occ End If Next file InventorVb.DocumentUpdate() 'Update
