I am very new to the iLogic function of Inventor (also poor with coding), and am looking to have the iProperties of a part autofill from an excel spreadsheet.
While I have found a line of coding that prompts the user to choose a specific row to pull the information from, the spreadsheet itself has multiple pages within itself. I was wondering if there was a line of code that would have the capacity to search through all of the pages for the line item, or prompt the user to make a selection as to what page it needs to reference. I have looked everywhere that I can think of to no avail.
Thanks in advance!
Hi andrewb,
Here is a quick iLogic rule that looks at each sheet in the excel file and searches for a value (myString).
I hope this helps.
Curtis
'define the string to search for Dim myString As String myString = "Bingo" 'define the file to open myXLS_File = "C:\Temp\ExcelWB-01.xlsx" 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run visibly, change to false if you want to run it invisibly excelApp.Visible = False 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = False 'check for existing file If Dir(myXLS_File) <> "" Then 'workbook exists, open it excelWorkbook = excelApp.Workbooks.Open(myXLS_File) oSheetCount = excelWorkbook.Sheets.Count Else 'workbook does NOT exist MessageBox.Show("The Excel workbook does NOT exist.", "iLogic") End if Dim sCellValue As String i2 = 1 Do until i2 = oSheetCount +1 'set the excel sheet to search GoExcel.Open(myXLS_File, "Sheet" & i2 ) 'count row data CurrentRow = 1 ' first row used i = 0 Do Until i <> 0 'look for empty string If String.isNullOrEmpty(GoExcel.CellValue("A" & CurrentRow)) Then i = i + 1 Else sCellValue = GoExcel.CellValue("A" & CurrentRow) If sCellValue = myString Then 'tell user which sheet and cell has the data MessageBox.Show("Value found on: Sheet" _ & i2 & ", A" & CurrentRow, "iLogic") End If CurrentRow = CurrentRow +1 End If Loop 'last used row NumberOfRows = CurrentRow -1 i2 = i2 +1 Loop ''close the workbook and the Excel Application excelWorkbook.Close excelApp.Quit
Thanks for the response, it looks like that should do what I'm looking for.
Though, the sheets in the document have names that aren't Sheet1, Sheet2, etc... Would that change the command entirely, or could I just drop out the loop and write it out to reference every sheet specifically?
Hi andrewb,
Here is a quick update to this rule that uses the sheet's actual name, rather than building the name string from "sheet" & sheets.count.
I hope this helps.
Curtis
myString = "Bingo"
'define the file to create/open
‘get the Inventor user name from the Inventor Options
myName= ThisApplication.GeneralOptions.UserName
'set Excel to run visibly, change to false if you want to run it invi2ibly
Else
End if
i2 = 1
oSheetItem = excelWorkbook.Sheets.Item(i2)
oSheetName = oSheetItem.Name
GoExcel.Open(myXLS_File, oSheetName )
'count row data
i = 0
Do Until i <> 0
i = i + 1
Else
MessageBox.Show("Value found on: " & oSheetName _
Loop
'last used row
i2 = i2 +1
Loop
excelWorkbook.Close
excelApp.Quit
So I've had this endeavor take on somewhat of a new form, and I needed it to do a bit more than I had originally anticipated.
I wrote out this code so that the user fills out a form with the iProperty data, then it searches for an existing part number/page in the excel spreadsheet and populates the correct cells. Also, if the part number needed is not in the excel file, it searches out the next unused row and populates the data there.
However, when I made the changes to seek out existing part numbers, find the next unused row, etc., the rule seems to have stopped working for some reason that I can't seem to find. I get no errors, and still get prompted to fill out the data on the form, but nothing at all happens past that.
I know that it is probably very cumbersome (as I am still new to the world of visual basic) but could someone take a look at my code to see maybe where I went wrong?
Sub Main iLogicForm.Show("iProperty Update") 'Open iProperty form Call CallData 'Run sub to find correct sheet for data input End Sub Sub CallData GoExcel.Open("C:\Path\FileName.xlsx") 'Open Excel file MySheet = (Left(iProperties.Value("Project", "Part Number"), 2)) 'Locate correct sheet for data unput If MySheet = ("AN") Then Call AN_Value ElseIf MySheet = ("BM") Then Call BM_Value ElseIf MySheet = ("CH") Then Call CH_Value ElseIf MySheet = ("EM") Then Call EM_Value ElseIf MySheet = ("FB") Then Call EM_Value ElseIf MySheet = ("GS") Then Call GS_Value ElseIf MySheet = ("PL") Then Call PL_Value ElseIf MySheet = ("PG") Then Call PG_Value ElseIf MySheet = ("SH") Then Call SH_Value ElseIf MySheet = ("RT") Then Call RT_Value ElseIf MySheet = ("SP") Then Call SP_Value ElseIf MySheet = ("ST") Then Call ST_Value ElseIf MySheet = ("UH") Then Call UH_Value ElseIf MySheet = ("UR") Then Call UR_Value End If End Sub Sub AN_Value Worksheet = ("C:\Path\FileName.xlsx") 'Find correct worksheet Sheetno = ("Angle") 'Open excel GoExcel.Open(Worksheet, Sheetno) 'Define Range RowStart = 2 RowEnd = 10000 For count = RowStart To RowEnd 'If it's blank count it Next RowNumber = GoExcel.FindRow("FileName.xlsx", "Angle", "New DWG #", "=", "Part Number") 'Locate present part number in excel file If RowNumber >= 1 Then GoExcel.CellValue("A" & RowNumber) = iProperties.Value("Project", "Part Number") 'Return present part number to iProperty Else If RowNumber = 0 Then Call AddRow 'Run sub to add data to new row End If End Sub
Ignore the last post's code.. I grabbed the wrong version. This should be the one that I am currently trying to debug.
Sub CallData GoExcel.Open("K:\Riley Vault\New Riley Part Log - Copy.xlsx") 'Open Excel file MySheet = (Left(iProperties.Value("Project", "Part Number"), 2)) 'Locate correct sheet for data unput If MySheet = ("AN") Then Call AN_Value ElseIf MySheet = ("BM") Then Call BM_Value ElseIf MySheet = ("CH") Then Call CH_Value ElseIf MySheet = ("EM") Then Call EM_Value ElseIf MySheet = ("FB") Then Call EM_Value ElseIf MySheet = ("GS") Then Call GS_Value ElseIf MySheet = ("PL") Then Call PL_Value ElseIf MySheet = ("PG") Then Call PG_Value ElseIf MySheet = ("SH") Then Call SH_Value ElseIf MySheet = ("RT") Then Call RT_Value ElseIf MySheet = ("SP") Then Call SP_Value ElseIf MySheet = ("ST") Then Call ST_Value ElseIf MySheet = ("UH") Then Call UH_Value ElseIf MySheet = ("UR") Then Call UR_Value End If End Sub Sub AN_Value Worksheet = ("K:\Riley Vault\New Riley Part Log - Copy.xlsx") 'Find correct worksheet Sheetno = ("Angle") GoExcel.Open(Worksheet, Sheetno) 'Open excel RowStart = 2 RowEnd = 10000 'Define Range For count = RowStart To RowEnd 'If it's blank count it Next RowNumber = GoExcel.FindRow("New Riley Part Log.xlsx", "Angle", "New DWG #", "=", "Part Number") 'Locate present part number in excel file If RowNumber >= 1 Then GoExcel.CellValue("A" & RowNumber) = iProperties.Value("Project", "Part Number") 'Return present part number to iProperty MsgBox("Inserting Data on Row " & row) GoExcel.CellValue("D" & row) = iProperties.Value("Summary", "Title") GoExcel.CellValue("E" & row) = iProperties.Value("Summary", "Subject") GoExcel.CellValue("F" & row) = iProperties.Value("Summary", "Category") GoExcel.CellValue("G" & row) = iProperties.Value("Summary", "Keywords") GoExcel.CellValue("A" & row) = iProperties.Value("Project", "Part Number") GoExcel.CellValue("C" & row) = iProperties.Value("Project", "Stock Number") GoExcel.CellValue("H" & row) = iProperties.Value("Project", "Description") GoExcel.CellValue("I" & row) = iProperties.Value("Summary", "Author") Else If RowNumber = 0 Then Call AddRow 'Run sub to add data to new row End If End Sub Sub AddRow If String.IsNullOrEmpty(GoExcel.CellValue("A" & count)) Then i = i + 1 End If 'Next empty row is max rows minus blank rows plus one row = RowEnd - i + 2 MsgBox("Inserting Data on Row " & row) GoExcel.CellValue("D" & row) = iProperties.Value("Summary", "Title") GoExcel.CellValue("E" & row) = iProperties.Value("Summary", "Subject") GoExcel.CellValue("F" & row) = iProperties.Value("Summary", "Category") GoExcel.CellValue("G" & row) = iProperties.Value("Summary", "Keywords") GoExcel.CellValue("A" & row) = iProperties.Value("Project", "Part Number") GoExcel.CellValue("C" & row) = iProperties.Value("Project", "Stock Number") GoExcel.CellValue("H" & row) = iProperties.Value("Project", "Description") GoExcel.CellValue("I" & row) = iProperties.Value("Summary", "Author") 'Insert data on new row GoExcel.Save End Sub
