Inventor General Discussion
Valued Contributor
2 Kudos
Post 1 of 5
ilogic code to fix part numbers / revision number
1171 Views, 4 Replies
04-11-2012 10:21 PM
Hi
I am after some help writing a ilogic rule to look at all part numbers on .ipt DocumentType = 12290
workflow is needed is to find all .ipt within assemblies and if part number on .ipt does notch match file name (without extension) then add.
Also on seperate rule if rev number equals (blank) or - then revision number on all .ipt to equal 1
Any help would be appreciated
Dave
Hi dclunie,
Here's a sample rule to do this. And thanks to Paul for the recomendation.
I hope this helps.
Curtis
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
'kAssemblyDocumentObject = 12291
If openDoc.DocumentType = 12291 Then
'Iterate though the part files in the assembly
For Each docFile In openDoc.AllReferencedDocuments
'kPartDocumentObject = 12290
If docFile.DocumentType = 12290 Then
'format file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
'returns file name with extension
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
'returns the number of characters in the file name
nameLen = Len(docFName)
'trims off the file extension (last 4 characters)
nameNoExtension = Left(docFName,nameLen-4)
'set part number to file name (without extension)
if iProperties.Value(docFName,"Project", "Part Number") <> nameNoExtension then
iProperties.Value(docFName,"Project", "Part Number") = nameNoExtension
else
end if
'check for empty Rev #
if iProperties.Value(docFName,"Project", "Revision Number") = "" then
iProperties.Value(docFName,"Project", "Revision Number") = 1
else
end if
'check for empty description
if iProperties.Value(docFName,"Project", "Description") = "" then
'get a description from the user
myDescription = InputBox("Enter Description.", "Description - "& docFName, iProperties.Value(docFName,"Project", "Description"))
iProperties.Value(docFName,"Project", "Description") = myDescription
else
end if
End If
Next
Else
MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!")
End If
Thank's very much for the code it works perfect and really fast ,it is appreciated
Dave
198 Kudos
Post 2 of 5
Re: ilogic code to fix part numbers / revision number
04-12-2012 05:20 AM in reply to: dclunie
Curtis Waguespaeck has a lot of great information on iLogic on his blog:
http://inventortrenches.blogspot.co.uk/2011/08/copy-design-and-revision-rolling-with.html
Check it out
CSO
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
1,702 Kudos
Post 3 of 5
04-12-2012 08:14 AM in reply to: dclunie
Hi dclunie,
I hope this helps.
Curtis
			'format  file name
        			else
        			end if
			else
			end if
			else
			end if
		End If
	Next
Else
End If
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
2 Kudos
Post 4 of 5
04-12-2012 09:35 AM in reply to: Curtis_Waguespack
Dave
198 Kudos
Post 5 of 5
04-12-2012 12:18 PM in reply to: dclunie
He's the man :smileywink:
CSO
