Inventor Forum
ilogic code to fix part numbers / revision number
5 REPLIES 5
3308 Views, 5 Replies
Hi
I am after some help writing a ilogic rule to look at all part numbers on .ipt DocumentType = 12290
workflow is needed is to find all .ipt within assemblies and if part number on .ipt does notch match file name (without extension) then add.
Also on seperate rule if rev number equals (blank) or - then revision number on all .ipt to equal 1
Any help would be appreciated
Dave
5 REPLIES 5
PaulMunford
Curtis Waguespaeck has a lot of great information on iLogic on his blog:
http://inventortrenches.blogspot.co.uk/2011/08/copy-design-and-revision-rolling-with.html
Check it out
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Curtis_Waguespack
Hi dclunie,
Here's a sample rule to do this. And thanks to Paul for the recomendation.
I hope this helps.
Curtis
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
'kAssemblyDocumentObject = 12291
If openDoc.DocumentType = 12291 Then
	'Iterate though the part files in the assembly
	For Each docFile In openDoc.AllReferencedDocuments
		'kPartDocumentObject = 12290
		If docFile.DocumentType = 12290 Then
			'format  file name
			Dim FNamePos As Long
	            	FNamePos = InStrRev(docFile.FullFileName, "\", -1)
	            	Dim docFName As String
	            	'returns file name with extension
			docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
			'returns the number of characters in the file name
			nameLen = Len(docFName)
			'trims off the file extension (last 4 characters)
			nameNoExtension = Left(docFName,nameLen-4)
			'set part number to file name (without extension)
        			if iProperties.Value(docFName,"Project", "Part Number")  <> nameNoExtension then
        			iProperties.Value(docFName,"Project", "Part Number")  = nameNoExtension
        			else
        			end if
			'check for empty Rev #
			if iProperties.Value(docFName,"Project", "Revision Number") = "" then
			iProperties.Value(docFName,"Project", "Revision Number") = 1
			else
			end if
			'check for empty description
			if iProperties.Value(docFName,"Project", "Description") = "" then
			'get a description from the user
			myDescription = InputBox("Enter Description.",  "Description - "& docFName,  iProperties.Value(docFName,"Project", "Description"))
			iProperties.Value(docFName,"Project", "Description") = myDescription
			else
			end if
		End If
	Next
Else
MessageBox.Show("You must have a valid Assembly document open before using this code!", "File Type Mismatch!")
End If
in reply to: Curtis_Waguespack
Thank's very much for the code it works perfect and really fast ,it is appreciated
Dave
PaulMunford
He's the man 😉
JorisSteurs1246
Sorry for jumping in a little late 😉
I found similar samples of iLogic on this forum to set iproperties in all leaf occurrences , but these samples never write to suppressed parts in the assembly.
Is it possible to have the code also effecting EVERY part in the assy included the suppressed ones?
All help very welcome
thanks
Joris
Autodesk Customer Advisory Groups
