Inventor General Discussion
Member
lewiuberg
Message 1 of 3 (347 Views)
iLogic code for opening a web page
347 Views, 2 Replies
04-20-2012 01:37 AM
Can someone help me with some code that will open my company`s webpage if the parameter is set yo <True>?
i have tryed alot of that is not working:
If Visit_firenor = True Then
ThisDoc.Launch("C:\Program Files\Internet Explorer\iexplore","http:\\www.firenor.no")
End If
Lewi
Curtis_Waguespack
Message 2 of 3 (329 Views)
Re: iLogic code for opening a web page
04-20-2012 07:28 AM in reply to: lewiuberg
Hi lewiuberg,
This should work:
Try
System.Diagnostics.Process.Start("http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-code-for-opening-a-web-page/td-p/3422965")
Catch
  MessageBox.Show("Could Not Open Page", "iLogic")
End Try
 I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
lewiuberg
Message 3 of 3 (296 Views)
04-23-2012 01:49 AM in reply to: Curtis_Waguespack
Works great!
Thank you so much :smileyhappy:
Lewi
