Can someone help me with some code that will open my company`s webpage if the parameter is set yo <True>?
i have tryed alot of that is not working:
If Visit_firenor = True Then
ThisDoc.Launch("C:\Program Files\Internet Explorer\iexplore","http:\\www.firenor.no")
End If
Lewi
Solved by Curtis_Waguespack. Go to Solution.
Hi lewiuberg,
This should work:
Try System.Diagnostics.Process.Start("http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-code-for-opening-a-web-page/td-p/3422965") Catch MessageBox.Show("Could Not Open Page", "iLogic") End Try
I hope this helps.
Curtis
