I'm wondering if it is possible to check-in drawing into vault using i-logic?
Why?
If you check-in a drawing into our vault, it automaticly exports a .dwf to a storage server. We also have a simple button for making .pdf of the drawing to sent to the customer.
What i want to ensure is that the .dwf file and the .pdf file are the same. So when i press "make a .pdf" the rule will save my document, make a .pdf and (if possible) check it into vault. So from that point the .pdf for the client and the .dwf on the server are the same.
Does anybody know how to to this and teach me?
Thanks!
What i have found so far is you are limited with ilogic and what you can do with vault directly. You can invoke the check in dialog eaisly though.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 1468 StartFragment: 314 EndFragment: 1436 StartSelection: 314 EndSelection: 314 SyntaxEditor Code Snippet
ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
I haven't found the way to have it select the "Ok" button yet.
ey, thanks for the quick reply!
Well, invoking the dialog box is a good start.
Maybe you know a way to add a comment? 😄
